73-79 options
Old Aug 2, 2006 | 10:28 PM
1ford1's Avatar
1ford1
73-79 options
I have several of these trucks...2 driving....5 parts. One of my parts trucks has intermittent wipers and a cargo light. I was curious if any of these came with cruise control?
Old Aug 2, 2006 | 10:31 PM
MBBFord's Avatar
MBBFord
Yes, cruise was a option, but pretty rare before 78, and it's not like the 78 79s were full of the either.
Old Aug 2, 2006 | 10:41 PM
1ford1's Avatar
1ford1
Thanks...I was considering converting one over from a car application. Not sure how difficult this would be or if it would be worth it.
Old Aug 2, 2006 | 10:45 PM
MBBFord's Avatar
MBBFord
There is alittle black box behind the dash, that I think controls everything, but you'd also need the 2 piece speedo cable, a extra wire behind the dash to plug into a little yellow 3 hole female connector, steering wheel(at least pad and buttons), and then it should work.
I have cruise on my 79 Bronco, but the previous owner disconnected somthing, so it doesn't work, not like I'd use cruise to much anyway(mostly my mud play toy).
Old Aug 3, 2006 | 12:14 AM
Mil1ion's Avatar
Mil1ion
There is A LOT more to it than what has just been mentioned.
do a search for "cruise control List" with my user name.
You need a special brake booster, brake switches,harness, and depending on what year steering column /wiring.
It's not a just simple add a couple of parts .
Old Aug 3, 2006 | 10:06 AM
MBBFord's Avatar
MBBFord
Thanks for clearing it up Mil1ion, I didn't remember everything it took, but just from what I named, it sounds like to much trouble to try and do much less, everything else.
Old Aug 3, 2006 | 10:33 AM
Mil1ion's Avatar
Mil1ion
The biggest problem right now is we weren't informed of what year the truck in question is.
It makes a difference
Old Aug 3, 2006 | 11:51 AM
Mil1ion's Avatar
Mil1ion
You will find my list on this thread.
https://www.ford-trucks.com/forums/s...d.php?t=249604
Old Aug 3, 2006 | 01:15 PM
n9lhm's Avatar
n9lhm
My 1976 brochure says that cruise is only available on the 460 engine for that year, anyway.
Old Aug 3, 2006 | 03:57 PM
1ford1's Avatar
1ford1
Thanks, sorry about the lack of info. The truck is a 1978 F100 Ranger XLT shortbed. The truck originally came with a 302,c6,dana 44 (3.00 gears), tilt wheel, a/c. I have added the intermittent wipers from the 1976 and the D1VE block 460, c6, 9" (3.50 gears). I intend to add the cargo light off the 1976 later. The cruise was not a definate add on to me, it depended on the challenges involved in adding it. I am still considering changing the c6 for a 4spd auto.
Old Aug 3, 2006 | 04:12 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Wasn't the cargo light on the 1976 like the ones off of the older trucks?
I thought 1977 was when they switched to the smaller cargo light lens.
Old Aug 3, 2006 | 05:28 PM
1ford1's Avatar
1ford1
I am not sure about the size. The only one I have seen is the one on my 1976.
Old Aug 4, 2006 | 08:03 AM
n9lhm's Avatar
n9lhm
The catalogs I have seen (Carpenter and LMC) both specify a serial # in the '77 model year as the change from the large to small cargo light.
Old Aug 4, 2006 | 12:06 PM
Mil1ion's Avatar
Mil1ion
is it ....Y80001 ?
51PanelMan
Ford Truck Parts for Sale
187
Feb 19, 2018 04:21 PM
camperspecial65
15
Nov 1, 2011 08:05 AM
berry1234
Jul 3, 2009 06:20 PM
ceetwarrior
1947 and Older Ford Trucks
Dec 29, 2005 09:44 PM
mikesfordf1
Jun 19, 2005 06:57 PM
