Sponsored by: Innova
JL Stealth Box?
Old Aug 2, 2006 | 07:20 PM
RonW.'s Avatar
RonW.
JL Stealth Box?
Newbie here, 1st post:
Anyone have the JL Stealth Box in a 06' SC Lariat? If so, how's the fit and sound? Also, is there enogh room behind the rear back seat to mounts the amps?
RonW.
Old Aug 3, 2006 | 09:20 AM
FTE Trigger's Avatar
FTE Trigger
Welcome to FTE Ron...
For your JL SB question, I canna be of too much help, but the space behind the rear seat is no-go for most of your standard issue/size amps. Unless you plan on keeping the rear seat off for some sort of air-circulation.
I'd prolly go for under the rear seat or under the front seats. At least that way you'll have some sort of air movement going on.
Old Aug 3, 2006 | 09:17 PM
LVEILLON's Avatar
LVEILLON
I listened to an 06 with a JL Stealth box that was in the center console and it sounded excellent. Only problems I had was that it was a bit pricey($500) and it consumes most of the center console. If you don't use the storage then it might be worth it. When it hit it was like having a jackhammer hit you.
Old Aug 8, 2006 | 08:17 PM
fjmaze's Avatar
fjmaze
ive got the center console stealth box and i like it. Came with the truck so price wasnt an issue. Has some nice tight bass somtimes to much so im looking into some 6" seperates for the doors or fitting some 6x8 in there. The rockford replacements that are in the doors sound good but somtimes i need a little more...
Old Aug 8, 2006 | 08:31 PM
LVEILLON's Avatar
LVEILLON
fjmaze...If you can find a FoCal speaker dealer in your area or close to you it will be worth your time. These are the best sounding door speakers that I've ever had. They are pricey, but well worth the cost. I heard them next to a set of the best BostonAcoustics.
I had never heard of this brand until I went in to buy a couple pair of BA's.
Old Aug 9, 2006 | 10:25 AM
Wedgewood Lariat's Avatar
Wedgewood Lariat
I haven't seen this console sub. I checked the JL website and still can't find it.
Old Aug 9, 2006 | 11:58 AM
FTE Trigger
I think this is the one their referring to... JL Stealth Downfiring
Old Aug 9, 2006 | 06:00 PM
fjmaze's Avatar
fjmaze
lveillon, are the focals seperates or the stock size? do u have them in u,re truck?
Wedgewood lariant, check out this ebay item.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=9723930241&rd=1&sspage name=STRK%3AMEWA%3AIT&rd=1
Old Aug 9, 2006 | 08:08 PM
LVEILLON's Avatar
LVEILLON
Yes...I have the FoCal's in my truck and they replace the stock speakers. I had seperates in one of my other F250's, but they were in kick panels that are nothing but a problem. They are always in your feet and especially in the FORD F250/350 series.
The StealthBox on the ebay site doesn't look like it's the correct one for the F250...You may be looking for an F150. I only buy new in box JL items since I got burned for buying an unboxed amp and after a month it died. No warranty repair and it had moisture damage. I use it to hold open one of the doors in my shop.
Old Aug 9, 2006 | 09:02 PM
fjmaze's Avatar
fjmaze
Ok.....the ebay site was so Wedgewood could see what it looks like.
Old Aug 13, 2006 | 01:17 AM
200Proof's Avatar
200Proof
I have the Stealthbox in my 04' Excursion with a JL Audio 300w amp pushing it & it hits hard as s***& I have the gains on the amp turned all the way down. If you are looking for some sweet sounding speakers try finding a shop that has Dynaudio and they will blow away every speaker including Focal, but they are power hungry, I had to add another amp because they were underpowered with 150w going to each speaker. I now have a JL Audio 300/2 bridged going to each speaker, so that's 2 300/2 amps puting out 600w driving one pair of component speakers.
Old Aug 19, 2006 | 07:54 PM
swengle's Avatar
swengle
I’ve got a JL Audio Stealth Box (SB-F-SUPRCNSL/10W3v2) in my 2005 F250 Crew Cab. Performs very well. Amps are behind the rear seat, mounted on a custom bulkhead I had fabricated. A JL Audio 250/1 drives the subwoofer, a JL Audio 300/4 amplifier drives the front and rear speakers (Boston Acoustics SL80s). Head end unit is a Kenwood DDX8017. I balanced the whole system using a sound pressure meter (Radio Shack) and calibration CD I got off the web.
Regarding the bulkhead, I mocked it up using a piece of fiberboard. I used that to develop a set of drawings that I handed over to a local metal fab shop. They made it out 3mm aluminum. The way I “staggered” the panel (can sort of see it in the picture) provides the clearance needed for the cab vents in the back wall of the cab, and provides the room to mount and ventilate the amps. Ford very conveniently provided four hard points to mount it.
Steve
Old Sep 21, 2009 | 09:05 PM
dwollenh's Avatar
dwollenh
RonW.
I had the console based stealthbox in my 06 Lariat SC with a JL 500/5 amp driving it and my front and rears. The amp was mounted to the back seat with no problem whatsoever. Sounded awesome and loved it! That little box hits hard! Those components are now for sale. if someone's interested, PM me an offer. I took them out before trading in, reused what I could in the new truck.
I traded the truck in for a 2010 Harley edition F350 and have gone with the new 900/5 amp and the new 13.5" Shallow sub behind the seat. The consoles setup for the newer Super Duties have a smaller Console space than the previous version. I like the shallow setup, hits harder with the bigger amp, but not quite as low as the stealthbox.
Old Feb 14, 2010 | 07:28 PM
sashi71's Avatar
sashi71
jl and amp 4 sale
I have a 2000 excursion wanted to know if they would fit and how much sashi71@aol.com or 917-807-6620 thanks sashi
Old May 22, 2010 | 12:42 PM
sashi71's Avatar
sashi71
jl stealthbox for the jump seast
I am selling the jl audio stealth box fot the 40 20 40 split front seat. You actually put it in and put the bottom seat cover over it chaeck it out on the jl audio website I think it fit's all99-2006 f-250 f-350 excursion and superduty. 917-807 6620. Located in NY thank you .
cangim
Aug 5, 2017 08:52 PM
blue&white
1978 - 1996 Big Bronco
Jul 9, 2017 07:56 PM
RonW.
2004 - 2008 F150
Nov 8, 2016 02:17 PM
slim813
Aug 31, 2016 03:04 PM
MCDavis
2004 - 2008 F150
31
Jan 27, 2012 01:23 AM
