'99 EB, no front AC?
Old Aug 2, 2006 | 05:41 PM
Hacker Hydro's Avatar
Hacker Hydro
Man this thing is crazy! Long story short...
The rear AC blows cold but the front blows hot. It has the automatic climate control and front and rear AC's. I can operate the rear AC independantly from the front. Even if I switch the front to vent and it is sorta cool out, it still blows hot air like the heat is switched on or something. We're going on Vacation soon and we'd love for the AC to back to normal.
My thought is the control panel is bad. I did a search but came up with hundreds of non related threads. Any help would be greatly appreciated.
Old Aug 2, 2006 | 07:45 PM
projectSHO89's Avatar
projectSHO89
Try SEARCHing for "blend door"
Pretty common failure if that's what yours is.
Control panel is a possibility, but I'd check for the blend door first. Of course, if it's the blend door, there goes your vacation dollars.
Steve
Old Aug 2, 2006 | 09:13 PM
Hacker Hydro
Wow, thanks for the heads-up.
I would have never known to SEARCH for "Blend Door".
Now that I have, I wish I hadn't.... LOL!
I guess I'll call the stealership tomorrow for the part. I will have no problem replacing it myself. I just wish my garage had air condition... It was 102* today, add the humidity and it feels like 115*.
Old Aug 3, 2006 | 01:10 PM
Hacker Hydro
I called the dealer and they have the assembly in stock, imagine that...
Problem is I'd like to just replace the door if I can with buying the complete assembly. I thought I saw on here that someone had replaced just the door and had gotten just the door from someplace, maybe not the dealer? Dealer says it only comes with the assembly.
Old Aug 5, 2006 | 11:50 AM
01silvergt's Avatar
01silvergt
research it some more and you will find the part number for the door alone. Just have to ask, you did read how long this takes and the amount of labor involved to do this yourself?
Old Aug 24, 2006 | 12:24 AM
jhermansen's Avatar
jhermansen
Cool
Any luck with finding and/or replacing the blend door on the 99 Exped.
I've got the exact same problem now.
Old Aug 25, 2006 | 11:28 AM
Hacker Hydro
I fixed it that weekend, about two weks ago. It sucked badly, but I have cold AC.
Trouble is my wife went out this morning to run some errands and it won't start. New battery didn't fix it either.
Old Aug 28, 2006 | 11:18 AM
lvmilkman2002's Avatar
lvmilkman2002
Just send me an email an I have the pictures on how to fix this...usually it is just the blend door motor and not the door itself...although that does break as well.
Good luck,
Milkman
xrocketscientist at *** dot net
Old Sep 2, 2006 | 01:22 PM
kbsvo2go's Avatar
kbsvo2go
Blend door repair
The door assembly is available from ford for about 45 dollars. You have to remove the dash to replace the door I did it in my driveway with the help of air tools in about 5 hours. just be careful not to break the clips and use a torque wrench when you reassemble to prevent any squeaks. Good luck PS looks for threads on removing the headlight switch. You can break it if not careful.
ttles714
Dec 19, 2013 06:30 PM
Munkey
Jun 27, 2013 08:04 PM
mgmoore7
Sep 12, 2006 07:01 AM
Tekwrecker
Aerostar
Jan 9, 2006 08:04 PM
Schlump
Feb 27, 2003 05:50 AM
