Overboost Regulater???
Old Aug 2, 2006 | 01:12 PM
Clint Knotts's Avatar
Clint Knotts
I ordered a DP-tuner with 40,60.and 80 econo settings,now I am wondering if I need a overboost regulater,and if a air compresser regulater would work if adjusted to 20 psi.I aso was looking at AIH plug for boost gauge and was thinking about making one,but I am not sure about the blue wire replacement to stop the code from setting.Can I make this wire and if so what do I need.
Old Aug 2, 2006 | 01:24 PM
clux's Avatar
clux
To make the code preventer you need a piece of wire and if I remember correctly about a 400 ohm 1/2 watt resistor from radio shack.
Old Aug 2, 2006 | 06:04 PM
Badluck's Avatar
Badluck
the over boost regulator is a chunk of wire that you can buy fomr sp diesel i just bought one and its nice to have with a chip so it doesnt kill your power
Old Aug 2, 2006 | 06:14 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i think the mechanical way is better. i went from the BCD dual relief valve to an ITB OverBoost regulator and it's worked great ever since.
Old Aug 2, 2006 | 06:15 PM
ryaneverk2's Avatar
ryaneverk2
Another good option for the overboost regulator (aka MAP sensor regulator) is the one from ITP Diesel:
http://www.itpdiesel.com/store.php?c...on=show_detail
Here's what it looks like installed:
http://community.webshots.com/photo/...86590301BpoLst
This is the best option as it doesn't bleed any actual boost off, so you're not loosing any boost as you do with a valve. It merely keeps the MAP sensor from seeing the higher boost numbers.
Old Aug 2, 2006 | 06:50 PM
Clint Knotts
Thanks, this ITP regulater is is what I had in mind.It seems to be the best option for my applacation.
Old Aug 2, 2006 | 08:21 PM
Kwikkordead's Avatar
Kwikkordead
I have the ITP regulator as well and it works great.
Old Aug 2, 2006 | 08:30 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Another vote for ITP.
Old Aug 2, 2006 | 08:49 PM
Dually02's Avatar
Dually02
Jody at DP Tuner sells the ITP regulaters.
Old Aug 2, 2006 | 09:43 PM
Clint Knotts
If I am thinking correctly, the ITP regulator will let the map senser see boost from 0 to 22 psi [what ever max is with out overboost] and send that info to the PCM.If this is true then the map sensor can read the boost across the board as well,whitch wouid let everything work as it is supposed to.This way of thinking makes the regulator a better choise over the pop-off valve because it is a small boost leak and the wiring harnness would show max boost all the time. Is all of this correct?
Old Aug 2, 2006 | 09:50 PM
PowerstrokeJunkie
yes yes and im not sure about the electrical deal.
i had the pop off valve setup and it was about an inch (in the MAP line) away from my boost Tee. when it activated you could see the needle jump around and it set the code on one of the spikes. it wasnt a constant pressure to the sensor, it was 24 20 25 20 24 20 etc. the regulator- 23 23 23 23 23 23 23
Old Aug 26, 2006 | 10:12 AM
k2vailkid's Avatar
k2vailkid
Made the same change, very happy with the ITP. Look at the demo videos on the ITP site about the differences between single, dual, and the ITP boost valves. It makes alot of sense.... $.02
Old Aug 26, 2006 | 04:20 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Yep, Dennis is the best!!!!!!!!!!!!
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Lil Red Sled
19
Nov 2, 2023 12:22 AM
evilhd
Aug 3, 2016 11:12 AM
bert cook
Oct 6, 2014 10:57 AM
revans9295
15
Apr 22, 2012 09:26 AM
crum71
15
Jun 20, 2008 07:23 PM
