brake line size?
Old Aug 1, 2006 | 11:12 AM
StangMang's Avatar
StangMang
brake line size?
94 Ford F-150 5.8L 351W SuperCab Flareside
My rear break line (the metal one) that runs down the drivers side to the back sprung a leak over the weekend. It was leaking really bad and i was getting no pressure. So I found were it was leaking and pinched the line ahead of it and only used my front brakes. So i need to get a new break line now.
Autozone.com asks what size; 3/16", 1/4", 5/16" or 3/8"? And also asks for the length; 20", 60", 40", 8", 12", 30" or 51"? I'm not sure which one it is. I've never switched a break line before. And are these easy to replace?
Old Aug 1, 2006 | 11:18 AM
MustangGT221's Avatar
MustangGT221
Cut off a piece of line and bring it with you to the store if you want...I don't know of the exact size...probably 3/16" or 1/4".
You'll have to measure the length and determine what you need.
You need a tube bender and flaring tool...which you can get at autozone for cheap (mgiht be able to rent them too). You need to flare the end of the tube after putting a fitting on.
Don't forget to bleed the entire system when you're done. Bleed it at the farthest point from the master cylinder first...closest last.
Old Aug 2, 2006 | 01:26 PM
dbuck50's Avatar
dbuck50
It is all 3/16 tubing. You can flare your own as mentioned, but an easy way is to buy 2 pieces of the right length (one 60" and whatever the other needs to be). Get a union fitting and you are all set and don't need to buy a flaring tool or worry about a bad flare/leak. BTW, I would replace all the lines if you had one blowout. They seem to go together since they all see the same weather.
Bilito
19
Feb 14, 2012 11:16 PM
MikePacey
Apr 12, 2011 07:01 PM
Franklin2
13
Nov 20, 2008 08:20 AM
jeremyd72
Jul 24, 2007 10:50 PM
G2IC_Wraith
1983 - 2012 Ranger & B-Series
15
Oct 3, 2006 04:47 PM
