Welding cable for batteries?
Old Jul 31, 2006 | 06:38 PM
trike1946's Avatar
trike1946
Question Welding cable for batteries?
I have one battery under the hood and one underneath on the frame behind the cab. I would like to move the other one to the back. Can I use welding cable for battery cables, or should I find somebody who makes the real thing. If I can, what size? Thanks for any help.
Old Jul 31, 2006 | 06:43 PM
Briansshop's Avatar
Briansshop
trike, I relocated both of my batts. to under the bed.I used 4/0 size welding cable.No probs, cranks as good as stock.
Brian
Old Jul 31, 2006 | 06:46 PM
trike1946's Avatar
trike1946
What did you use for the ends?
Old Jul 31, 2006 | 06:53 PM
Briansshop's Avatar
Briansshop
I had a local battery supplier make 'em up for me.Crimped on the batt clamps & lugs,w/heat shrink for the starter,solenoid, and so on.
Brian
Old Jul 31, 2006 | 07:04 PM
plowhand's Avatar
plowhand
Playing in the Dirt
You can also try your local tractor company or big truck garage. I know that the tractor companies have battery cable (black & red) by the roll. They make up battery cables to the lenght needed and have a variety of ends they can crimp on. Around here the battery cable is cheaper than welding cable, due to welding cable being fine strand and battery cables being course strand.
Old Jul 31, 2006 | 07:27 PM
trike1946's Avatar
trike1946
Thanks for the replies.
I have an E series so it is a little hard to tell where everything goes, but it looks like it is battery to battery (pos to pos) and then to the engine. Does one negative go to the frame and one to the engine?
Old Aug 1, 2006 | 04:16 AM
Cuda_jim's Avatar
Cuda_jim
Not sure about the van, but mine (f350) goes (neg to neg, battery) then to engine block. There is another ground strap that goes from block to the chassis.
Old Aug 1, 2006 | 12:14 PM
utahcrew's Avatar
utahcrew
Hay Trike this is my lack of knowladge but why do you what to move the batteries to under the bed? Please let me know.
Old Aug 1, 2006 | 12:49 PM
fishmanndotcom's Avatar
fishmanndotcom
prolly cause its an easy way to help de-clutter the engine compartment. not to mention help better distribute a little bit of weight.
i've been meaning to do it as well, just havent taken the time
-cutts-
Old Aug 1, 2006 | 06:28 PM
trike1946's Avatar
trike1946
Moving the battery will give me a little more room under the hood. I can then change the intake, as well as having room to do normal service and repairs. Right now I can't do anything without first pulling out the intake. With an E series you can't get to anything or even see most of it. It will run better with a different air filter. I am also adding a hood scoop and something underneath to pull in air.
