Here is an IDEA!!!
Old Aug 1, 2006 | 09:21 PM
RDC F250 7.3's Avatar
RDC F250 7.3
Ok, Blending 50/50 is bad, b/c "Blending it with any petroleum product or by-product is not a good idea because the two will seperate"
Ok, got that. Thats talking about using it in PSD's, But what about using it in 300hp Cummins Dump Truck 89ish. Also running it in 95* weather, burning most of the blend out that day, adding say 25 gallons of dino before you shutdown, then the next AM add 25 gallons of WVO???
Then burning that out that day, I Burn about 40-50 gallons a day. Per truck
Don't get me wrong I'm building a Processer, small one 30-40 gallons a day, but I need more fuel per day @ 5miles to the gallon!!!
Thanks Bobby
RDC
Old Aug 2, 2006 | 12:58 AM
Phydeaux88's Avatar
Phydeaux88
Mixing WVO is flat not a good idea.
If you want to burn WVO convert the truck and run straight WVO with startup and shutdown on either Dino or Bio.
No matter what you do the VO will seperate from the diesel, its a matter of physics and you cannot change those laws.
After seperation you will be running what ever layer the fuel pickup is drawing from. If it happens to be VO startup will be a problem. Additionally running cold VO is very likely to damage your engine.
I dont know what conversion will be necessary for the 89 Cummins. I believe the IDI internationals are a little more tolerant of unheated VO but you will have to ask some one that has experience with it.
I suggest LESKWVO
Old Aug 2, 2006 | 07:02 AM
PSNut's Avatar
PSNut
Originally Posted by IABill
I am not sending a dollar to the middel east for the last four months.......
...don't u love that feeling!!
Nut
Old Aug 2, 2006 | 12:21 PM
Phydeaux88's Avatar
Phydeaux88
Nut
All I can say is AMEN
Old Aug 2, 2006 | 01:04 PM
catbird7's Avatar
catbird7
RDCF2507.3 I have been running a blend for 1 1/2 - 2 years now with no problems. My potential loss is a $2500.00 1989 F350 4x4 7.3 5-spd. I would definitely have a different point of view if my "TEST TRUCK" was a $40,000.00 2006 PSD. The small potential loss has allowed me to experiment with blends. Disregarding warnings from others I took a neutral point of view and investigated (via the internet) used motor oil and filtered vegtable oil. Through this investigating and my "short" personnal experience this is what I see: 1.) Filtered vegtable oil mixed with diesel (using my eyes) remains mixed. Maybe it is not mixed at a molecular level but the mixture I put in a clear glass jar did not separate like vegtable oil mixed with water. 2.) Used motor oil can definitely be used as fuel ADDITIVE in diesel engines. It is a common practice in large truck fleets to burn used motor oil as a maintenance cost reduction. Some of them use a system called Centinel Oil Management which delivers used motor oil from the crankcase directly to the fuel tank. It's done slowly and over many miles, but it's done and these engines cost a little more than my $2500.00 clunker.
Old Aug 2, 2006 | 01:26 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
One thing to remember is the older trucks with the IDI system will allow for large variance in fuel types. Where as the newer electronic injection is very intolerable to any variance in fuel.
Old Aug 2, 2006 | 07:26 PM
CHPMustang's Avatar
CHPMustang
Smile
I been running WVO blend for the last 2,500 miles in our '02 and the truck never ran this good!
Safe alternative fuels is a beautiful thing!
Old Aug 2, 2006 | 09:52 PM
RDC F250 7.3
What has been your blend %'s? I would like to go with a 50/50, Today I burned 40 gallons. Thats 2.98 x 40 = 119.20. I would rather see 60.00 bucks coming out of the pocket.
Also I'm going to get a laser temp gun, and check the temps, @ the inside the fuel tank (fuel), @ the fuel filter, ( right next to the engine ), and @ the injection pump.
I just want to see how warm it gets!!
RDC
WatsonR
Nov 25, 2014 01:02 PM
FoxNotch
1997 - 2003 F150
Feb 5, 2013 09:52 PM
beardsly
Feb 11, 2011 11:48 PM
rusted&busted
Sep 14, 2010 01:52 PM
acaptain30
Jul 12, 2007 09:09 PM
