Oil Pump Question
Old Jul 29, 2006 | 04:16 PM
Andrew Landwehr's Avatar
Andrew Landwehr
Oil Pump Question
I'm tearing down my 360 to rebuild it. In doing so, I've tried hard to document how everything was put together so when I reassemble, it will go back easily.
However, when I took the oil pump out I didn't pay attention to the way the pump drive shaft was situated. There is a spring washer close to one end of the hex key shaft and I don't know how it went in. Does the spring washer go towards the pump or the distributor? I have a picture of the shaft in my gallery, but I don't know how to post a link.
Any help will be appreciated.
Old Jul 30, 2006 | 08:51 AM
390fe's Avatar
390fe
The spring washer side goes towards the distributor, but you've got to install it from the bottom of the block. You want the washer on the underside of the lower distributor boss. That way when the distributor gets pulled, the washer holds the shaft in the block.
steinernm
Jun 3, 2020 09:25 AM
jawsfree
2004 - 2008 F150
Jun 30, 2015 04:48 PM
jswford
1983 - 2012 Ranger & B-Series
Nov 5, 2014 05:11 AM
Scouder
Apr 12, 2004 04:21 PM
supercab78
Apr 19, 2002 01:03 PM
