surges and dies?
Old Jul 29, 2006 | 04:04 PM
bballcrf's Avatar
bballcrf
surges and dies?
hey guys my 1997 psd lately has surged twice, once while doing 65 on the freeway ,and the other while turning a corner.today while sitting at a light the truck died.started right back up and ran fine,i think when it died i lost all power a/c and radio not totally sure though.had checker check the batteries and alternator they said the whole system is fine and everything is tight.ive read other posts im thinking computer or cam sensor?my search will not wok for some reason.please help i love my psd!!
Old Jul 29, 2006 | 04:05 PM
1997F-350's Avatar
1997F-350
CPS
get one off ebay around 50 bucks.
Old Jul 29, 2006 | 04:12 PM
bballcrf's Avatar
bballcrf
so that sounds like the computer?is there a way i can test this computer?what are signs of the cam sensor going bad?
Old Jul 29, 2006 | 04:32 PM
1997F-350's Avatar
1997F-350
cps= cam position sensor
Old Jul 29, 2006 | 04:49 PM
bballcrf's Avatar
bballcrf
oh u guys say cam position sensor and not the computer.does the computer just die when it goes bad and the truck not run at all?
Old Jul 29, 2006 | 04:55 PM
1997F-350's Avatar
1997F-350
the computers hardly ever go out on our trucks.
now the cps(cam position sensor) on the other hand those go out quite often. signs are your truck will just die randomly on you or wont run at all.
Old Jul 29, 2006 | 07:43 PM
bballcrf's Avatar
bballcrf
does the cps have a square plug and is it between the crank and waterpump pulley?
Old Jul 29, 2006 | 08:25 PM
tjbeggs's Avatar
tjbeggs
sort of. the cps is located at about a 10 o'clock location on the crank pulley. it has a hold down bracket that looks like it could be a pointer for timing marks on the crank dampner
tjbeggs's Avatar
tjbeggs
sorry it not on the pulley but on the block at 10 o'clock
Old Jul 31, 2006 | 12:46 PM
dragman's Avatar
dragman
My '96 has started to do the same thing. Stop to make turn etc, the truck dies but starts right back up. Sometimes after engine starts it wont rev up and sputters. Almost sounds like when a motor hits a rev limiter. Trun off and start up again and all is fine. I have replaced the air and fuel filter and bought fresh diesel. I have a new CPS so I guess that is next.
Old Jul 31, 2006 | 12:52 PM
Level2's Avatar
Level2
Yeah, CPS is common and also if you have a chip in the PCM check the contacts and make sure everything is clean and tight. I had to change the CPS in my 97 F350 at about 115K miles because of intermitant signal.
Old Jul 31, 2006 | 12:59 PM
strokenalong's Avatar
strokenalong
Yup. Sounds like another CPS bites the dust.
Old Jul 31, 2006 | 01:39 PM
bballcrf's Avatar
bballcrf
thanks for the help guys, my next question and dont laugh too much, how do i use eabay? at 50 bucks id rather do it this way ,dealer wants 180 bucks,i have a friend that can pay on ebay but i need to know how to find it first.thx again
Old Jul 31, 2006 | 07:09 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Log onto ebay, go to setup an account. Set it up. Go to advanced search, go to ebay motors catagory. Click on parts, type in CPS. With the account you can bid and pay for it yourself.
Old Jul 31, 2006 | 07:13 PM
Level2's Avatar
Level2
I have found a couple on ebay but if it is easier for you, International carries the same part for a lot less money than what a ford dealer wants for it. Here are some ebay links to CPS sensors, just click on them.
http://cgi.ebay.com/ebaymotors/NEW-7...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/FORD-...spagenameZWDVW
