Modular V10 (6.8l)
Do I have MAF?
Old Jul 29, 2006 | 11:53 AM
Sport45's Avatar
Sport45
Do I have MAF?
I went to clean my MAF sensor today, but couldn't locate it. All I see is the IAC and what appears to be a TPS (throttle position sensor). Does a 2000 model V10 have MAF? If so, where is it. I'm assuming brake cleaner and a gentle scrub with a Q-tip will suffice for cleaning once I have ity out.
Thanks!
Old Jul 29, 2006 | 12:13 PM
V10KLZZ71S's Avatar
V10KLZZ71S
Right past the air cleaner housing going towards the engine. I clean mine with starting fluid it removes any oil/dirt build up and I dont use a q tip at all. Just let it dry before starting.
Old Jul 30, 2006 | 07:50 AM
captchas's Avatar
captchas
Guest
dito here! it is a small one with 2 screws holding it to the pipe on mine
Old Jul 30, 2006 | 10:04 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
On my 2001, it is buried inside the air cleaner housing.
Take the air filter out, disconnect the big hose going to the throttle body, and remove the air filter housing (the part towards the engine). Disconnect the wiring harness, there's a plug right there on the fender well.
After that, the inside of the air filter housing comes out and the MAF is inside there. To remove the sensor, you need an anti-tamper torx bit (the ones with the hole in the middle to match the pin in the screw).
Sorry I can't be more specific, I can't remember exactly how the inner housing comes out of the shell.
Old Jul 30, 2006 | 06:02 PM
Sport45's Avatar
Sport45
Thanks! Found it in what I'll call the downstream half of the air filter housing. I didn't unplug it or get it out of the housing, but I was able to hose it with electronic parts cleaner from both sides.
joe blow
Jun 4, 2013 12:36 AM
khadma
1997 - 2003 F150
Sep 24, 2011 11:01 PM
xc4jokestomper
26
Jul 28, 2010 08:58 PM
thelonerangerxlt
Dec 4, 2004 06:04 PM
omnithesis
May 10, 2004 11:14 AM
