sticking starter
Old Jul 29, 2006 | 10:23 AM
Shovelhead 93's Avatar
Shovelhead 93
Cool sticking starter
My 87 with 5.0 had a starter (new)put onit in january now it is starting to stay engaged and whine what is the deal??
Old Jul 29, 2006 | 10:37 AM
'88_F-150's Avatar
'88_F-150
did they put a new soleniod in the truck bucause when a starter stays engaged its usually a sticking soleniod
Old Jul 31, 2006 | 11:35 PM
GoBama's Avatar
GoBama
I've been there...and it was a bad solenoid. Luckily, it's a cheap part.
Old Aug 3, 2006 | 07:51 AM
Shovelhead 93
Ya I put new solenoid in still does the same thing,grinds when trying to turn over and starter stays engaged,shut it off try again sometimes ok
Old Aug 3, 2006 | 07:54 AM
Shovelhead 93
also I have the starter out and there is no clip to stop gear from going past groove in shaft is this a problem???
Old Aug 3, 2006 | 09:05 AM
marioc956's Avatar
marioc956
im new hear i dont know if you fixed the problem but i have a 1988 ford f150 with the same problem and the problem was the wire to the solenoid was to thin so i went with a 4gauge wire from the battery to the solenoid and i also put a heavy duty solenoid from orielly's auto parts
Old Aug 3, 2006 | 11:41 AM
Shovelhead 93
Problem solved I dug up one of my old starters and it had the clip so I put in on and it works great gear was going out to far thanx for all the input
knapikmichael
Jun 5, 2007 06:13 AM
PAUL_2
Jul 4, 2006 04:19 PM
jimdandy
Electrical Systems/Wiring
Mar 4, 2006 08:17 PM
toolebox1
Nov 9, 2005 11:51 AM
TOUGHLover
1983 - 2012 Ranger & B-Series
Dec 5, 2002 06:13 PM
