stuck distributor
Old Jul 31, 2006 | 12:34 PM
  #31
Mil1ion's Avatar
Mil1ion
Copy and paste them into your address bar by getting access through the quote feature.
Old Aug 2, 2006 | 04:11 PM
  #32
Alvin in AZ's Avatar
Alvin in AZ
Since aluminum expands faster than iron heat will make it worse.
Anybody ever try dry ice for this job?
WD-40 is mostly Stoddard's Solvent which can be good for certain things??
I've had the best luck loosening stuff up with carburetor cleaner.
Tell that to the guys at a wrecking yard and they'll usually respond with "antifreeze ". Never tried it tho. :/
Anybody ever try antifreeze?
My dad used, used brake fluid, I only use it for paint remover but lately, the paint is different or the brake fluid is different, it hasn't been working so good for paint remover. Got any ideas on that?
Alvin in AZ
Old Feb 14, 2008 | 06:26 PM
  #33
jconant's Avatar
jconant
jc in AZ - thanks!
Thanks for all the great ideas! I've got an '80 400 with the same problem, so I'll try the penetrating oil.
Old Feb 14, 2008 | 07:22 PM
  #34
Mr. G's Avatar
Mr. G
I think the problem is other than two surfaces being "stuck" together. On my 74 F250 390 it would happen where I would go to adjust the timing and the distributor would not move at all. I would drive it and check again and it would move easy. Then I would drive it again and it would become stuck. And on and on. Who knows really.
Old Feb 14, 2008 | 07:41 PM
  #35
JBradley500's Avatar
JBradley500
i used a PB Blater, a 2x4 and spun it in the hole. it took a few good wacks with an estwing but, back and forth i went. finally it came out.
