Hydro-boost brake system
Old Jul 27, 2006 | 10:53 PM
gotta56's Avatar
gotta56
Wondering what people think about this system. Looks like it would be simple to install, take a whole lot less room under the floor or under dash... Not actually that expensive(I think) just pick up the booster and a new power steering pump at the bones yard for $200?? Has anyone done this? How was the install and price?
Thanks for any comments
Karl
Old Jul 27, 2006 | 11:12 PM
HT32BSX115's Avatar
HT32BSX115
You're talking about the GM power steering pump boosted brake system?(My Suburban has that)
That would probably work well if you already had power steering. If not, tt would be quite a job I think. It might also be hard to adapt it to the thru-the-floor pedals etc.
Vacuum systems work well and there's several after market vacuum boosted systems available for most of the old Ford trucks.
The factory vacuum boosted system on my F-600 works well as is.....I'd like to have a split (front/back) system though.
Regards,
Rick
Old Jul 27, 2006 | 11:40 PM
gotta56's Avatar
gotta56
Yes, that is the system I am referring to. My problem is that I don't have enough room under my cab between the frame and the custom X member I made. I was trying to decide to do manual brakes or ?? No Limit sells a hydroboost brake system for hot rods. Doesn't look that complicated. I have Corvette 4 wheel discs, and think I will need some assist (booster). Also, I will have power steering, so that won't be a problem.
Check my pics
Karl
Old Jul 28, 2006 | 04:55 AM
boilerbots's Avatar
boilerbots
I did this and it works well. I got a hydroboost from an 84 suburban with diesel engine. This is the booster with a small reserve chamber on the side. It will give you 1 or 2 pumps without the engine running before the pressure it depleted. This helps when the engine is idling and you are turning the steering and using the brakes like in a parking lot.
I got the hydroboost bracket from No Limits engineering. You can buy just the bracket for the booster along with the pieces to adapt the stock pedal to the booster. I kept the GM master cylinder.
Everything works good. The only problem is the clearance above the master cylinder to get the lid on and off. I ended up machining my own flat lid and hold it on with some straps around the MC.
No limit seems to use a corvette MC that has a remote resevoir. That would work better but cost a little more.
Old Jul 31, 2006 | 09:02 PM
gotta56's Avatar
gotta56
Thanks for the reply, Boilerbots! That's what I wanted to hear. Did you use residual pressure valves, etc. just like a vacuum booster system?
Old Aug 1, 2006 | 03:56 AM
boilerbots's Avatar
boilerbots
If you mean in the brake lines, then yes. You need to because the master cylinder is so low that the brake fluid can flow back and cause the brake pads to release so much that the gap can become quite large requiring you to pump the brakes.
This has nothing to do with power brakes or manual brakes, it has to do with the master cylinder postions height relative to the wheels.
bldude2288
1983 - 2012 Ranger & B-Series
Oct 4, 2014 07:57 PM
Bigpipes 35
Oct 11, 2013 11:36 AM
cdaily91
2004 - 2008 F150
Jan 10, 2009 09:09 PM
Ole Gray
2004 - 2008 F150
Nov 3, 2005 07:05 PM
