Need help identifying an engine
Check the FE forum out, they can probably help you out with better ideas. I am familiar enough with standard FEs that I can tell the difference, but I don't know the measurements.
Good luck.
CODE A = 330MEDIUM DUTY/2V FORD CARB. 160HP@3800RPM
CODE M = 330HEAVY DUTY/2V HOLLEY CARB. 160HP@3800RPM
CODE K = 361 / 2V HOLLEY 176HP@3800
CODE 9 = 391 / 4V HOLLEY 199HP@3800
330 MEDIUM DUTY USED A NODULAR CRANK WITH A CASTING# OF 2T, WITH AN OVERALL LENGTH OF 27 AND 15/16" WITH A SNOUT DIAMETER OF 1 AND 3/8"
330 HEAVY DUTY/361 USED A FORGED STEEL CRANK WITH AN OVERALL LENGTH OF 28 AND 3/16" WITH A SNOUT DIAMETER OF 1 AND 3/4"
391 CRANKS HAD A CASTING # OF C6TE6303E AND WERE FORGED STEEL WITH AN OVERALL LENGTH OF 28 AND 3/16"
330MD HEAD CASTING# = C4TE6090C OR C4TE6090E
330HD/361/391 HEAD CASTING # = C4TE6090A OR C4TE6090D
330MD CARB.# = C4TF-AK,C4TF-BN,C6TF-A,OR C7TF-J ALL WERE FORD 2V CARBS
330HD CARB# = C4TF-A,C4TF-BY, C5TF-AS, C6TF-BE, OR C7TF-A ALL WERE
HOLLEY 2V CARBS.
361 CARB# = C4TF-C, C4TF-BZ, C5TF-AU, C7TF-B, C7TF-AD ALL WERE HOLLEY 2V CARBS
391 CARB# = C4TF-F, C4TF-CA, C5TF-AT, C7TF-U, C7TF-AE ALL WERE HOLLEY 4V CARBS
I HOPE THAT THIS HELPS YOU SOME IF THERE'S ANYTHING ELSE YOU MIGHT NEED INFO ON JUST LET ME KNOW
