y-block engine number
Old Jan 29, 2008 | 04:00 AM
aussie 700's Avatar
aussie 700
I recently acquired an F700 and can't find the engine number. Can anybody help?
Old Jan 29, 2008 | 04:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
In the USA there is no engine number (after 1948)...the vehicle is registered by the VIN = Vehicle ID Number.
The VIN will be on a metal plate riveted to either the door face near the latch, or inside the glove box door.
In the US, the VIN has codes for the year, engine size, truck series and assembly plant.
What year is your F700?
Old Jan 29, 2008 | 07:14 AM
312's Avatar
312
if your just looking to see what block you have its back by dist,before 57.after that its above the oil filter.
Old Jan 29, 2008 | 12:34 PM
NumberDummy
Since the OP failed to mention the year of his F700...there could be several different Y blocks.
It could be a 272/292 or the Lincoln based versions: 302 or 332: Dizzy behind carb.
After 1964, it could be an FT engine (dizzy in front of carb).
Technically speaking, both the FE & FT engines are also Y blocks.
Old Jan 30, 2008 | 01:25 AM
aussie 700's Avatar
aussie 700
sorry, should have mentioned I think it is about 1962 ( in Australia ). Has 2 bolt rocker covers and 4 barrel holley. Cab has single headl;ights with parking lights in grill. Any help?
Old Jan 30, 2008 | 03:36 AM
NumberDummy
Does the grille say F O R D in the center (1961), or is there a 4 pointed star in the center (1962)?
Parts catalog doesn't list a 4V carb for 1962 F700.
But I only have USA resources.
Did you find any ID numbers, either on a metal plate riveted to the door face, on the inside of the glovebox door, or on the firewall?
Is there a triangular shaped tag bolted to the top of the carb?
There are two possible Y block engines, neither share much with the other. There's the 292, and the Lincoln based 302/332.
fordloverf700
Jan 5, 2014 11:26 AM
dougbrown
Oct 13, 2011 09:56 PM
f700
Nov 9, 2004 10:27 AM
