Water Pump Bolt Torque
Old Jul 25, 2006 | 01:36 PM
SulliesRock's Avatar
SulliesRock
Unhappy Water Pump Bolt Torque
Does anyone know what the torque values should be on the bolts that clamp the water pump to the engine block?
Old Jul 25, 2006 | 04:54 PM
dagren99's Avatar
dagren99
Smile WP Torque
I believe it's 18ft lbs - someone else will prob chime in to confirm. I know the service CD has the wrong values in it.
DG
Old Jul 25, 2006 | 07:13 PM
Uzumati's Avatar
Uzumati
I do believe you are exactly correct (25nm / 18ft/lbs)
Old Jul 25, 2006 | 07:31 PM
lancer's Avatar
lancer
Exactly what i had in mind to!!
Old Jul 26, 2006 | 09:25 AM
nodakford's Avatar
nodakford
18lbs-ft. If you use the 35 lbs-ft you will snap the bolt head right off. I fouynd out the hard way. Make sure you get the right size bolts in the right spot.
djed
Mar 23, 2016 06:17 PM
YZ450F
1997 - 2003 F150
Sep 17, 2015 05:57 AM
peka
20
Sep 8, 2015 11:50 AM
aurgathor
Oct 13, 2004 11:25 PM
Tommyquest
May 14, 2004 09:06 PM
