2wd to 4wd conversion
Old May 18, 2013 | 01:21 AM
  #46
95_Dually's Avatar
95_Dually
Wow, I haven't seen this thread in years. LOL
EDIT: I posted on here nearly 7 years ago and my truck is still 2 wheel drive.
Old May 18, 2013 | 07:30 PM
  #47
fordman67's Avatar
fordman67
I guess you aren't in a hurry to get it done!
Old May 18, 2013 | 08:35 PM
  #48
95_Dually's Avatar
95_Dually
Life is always getting in the way of my wants....LOL
Old May 18, 2013 | 10:25 PM
  #49
Brown Falcon's Avatar
Brown Falcon
Ya got that right...
Old May 18, 2013 | 10:28 PM
  #50
fordman67's Avatar
fordman67
Story of my life!
Old May 19, 2013 | 04:42 PM
  #51
El Camino Man's Avatar
El Camino Man
Hey guys, Iv been wanting to trade off my dually for a 4wd, but after reading this thread, it looks easier than I originally thought to convert to 4wd. Iv read somewhere else you need to stiffen the front frame before you can add 4wd. Is this true?
And is it REALLY a direct swap or will I be drilling new holes in the frame and so fourth?
Old May 19, 2013 | 04:51 PM
  #52
fordman67's Avatar
fordman67
I thought i read where front leaf mounts were different on 2wd vs 4wd. don't take it to the bank.study and then get to work...
Old May 19, 2013 | 05:42 PM
  #53
95_Dually's Avatar
95_Dually
2wd is coil spring. The frames are the same.
Old May 19, 2013 | 05:45 PM
  #54
fordman67's Avatar
fordman67
That's cool.i for some reason thought the shakle pocket was not there on 2wd.got to love ford not retooling for every difference.
Old May 19, 2013 | 06:17 PM
  #55
El Camino Man
^^^ Agreed. They may mess up their bolts by having standard AND metric on the same truck and sometimes the same part, but they did good by making everything else swappable (if that's a word)
Old May 19, 2013 | 09:58 PM
  #56
Briansshop's Avatar
Briansshop
The frames are the same but the shackle mount is not there on the 2xs. Can be added. Most want a little lift so a shackle reversal kit is an easy way to get a front spring mount.
Old May 19, 2013 | 10:29 PM
  #57
Brown Falcon
You'll be drilling holes. If you weld on the 4x4 front frame pieces (shackle mounts) then you'll still need to drill 3 holes for the rear spring mount.
2wd frame doesn't have the shackle pocket. Not boxed on the front like the 4x4 frame.
You are correct. No shackle pocket on the 2wd. Doesn't matter if you do a RSK like I did. I fabricated brackets to box in the frame where the RSK mounted though.
Old May 19, 2013 | 11:27 PM
  #58
95_Dually's Avatar
95_Dually
I wonder if mine is an exception. I had it next to a 4X4 and it looks identical.
Old Feb 5, 2019 | 05:31 PM
  #59
almondjoy's Avatar
almondjoy
I have two 1997 f-350 Power strokes, one 2wd supercab 5 speed dual rear wheel the other 4x4 cc auto.single rear wheel. I need a dual rear wheel 4x4 for my business. how hard would it be to put dually rear end under the crew cab?
Old Feb 5, 2019 | 05:54 PM
  #60
Brown Falcon
As long as it isn’t a “cab and chassis” frame truck (F-Superduty) it’s direct bolt on swap. I did it to my ‘95 crew cab dually. Swapped a single wheel axle and bed onto it. You may need to swap the driveshaft yoke or use a conversion u-joint, though.
