2wd to 4wd conversion
Old Jan 15, 2010 | 09:00 AM
  #31
joe_13894's Avatar
joe_13894
Originally Posted by Kenworth
We have problems with people that are from east of the Rockies coming here in the winter time and figure we can drive in snow no problem. The biggest problem is the snow where they are from is drier its sticky so your tires bite into it. Here its wet and heavy you make a snow ball and throw it at somebody its like throwing a rock at somebody its hard.
Not only is the snow worse, for many of them it is the first time they've driven on a hill. Powder on the flat is nothing compared to Cascade snow on hills.
Old Jan 15, 2010 | 09:02 AM
  #32
joe_13894's Avatar
joe_13894
Originally Posted by fishmanndotcom
not sure of the compatibility of 01 D60 front with 96 F350 chassis. i KNOW for SURE a D60 out of any 86 to 97 1 ton will bolt right in with out any drilling, cutting or welding.... i've done it several times.
-cutts-
sooperdoody's have metric centering hubs and a metric bolt pattern. Unless you change the back you'd have different bolt patterns front and back.
Plus sooperdoodys front axles have the unit bearings that are $300 instead of $20.
Old Jan 16, 2010 | 05:26 PM
  #33
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
Originally Posted by southernchaos
have a question i have spent too much money swapping my truck over from 2wd to four wheel drive i have installed a 6 inch lift the chicken wing dana front axle 3inch blocks in the back with add a leafs the truck is a 1994 ford f150 4x2 sport is with m5r2 trans will a 4x4 tail housing and transfer case i bought used out of a 1993 f150 4x4 fit this truck or is the shafts inside a 2wd and 4wd m5r2 trans different please help me with this or direct me to somewhere on this site that can any help will be greatly appreciated
I know the e40d auto trans has different length shafts, its could be possible you have the same thing, you best place to check is the f150 forums as your trans does not bolt behind our engines
Old Feb 17, 2010 | 10:17 PM
  #34
chinmusic94's Avatar
chinmusic94
2x4 conversion
can u make a 1965 F250 2wd truck into a 1965 F250 4wd truck
Old Feb 17, 2010 | 10:26 PM
  #35
joe_13894's Avatar
joe_13894
You can do "anything" it is only how hard you try.
A 65 would have had a divorced T-case. That's probably the easy route.
Old Jun 16, 2010 | 10:50 PM
  #36
snakethis69's Avatar
snakethis69
is this thread still open? I have a 1993 F350 7.3L that I want to convert to 4WD but from what I understand they didnt make the 350 in 4WD in that year? What year can i get donor parts from?
Old Jun 16, 2010 | 11:03 PM
  #37
Midwest Dually's Avatar
Midwest Dually
This is kind of an old thread.. Dont know if these same people frequent! LOL!
If you want something a little more recent, you can check out mine...
https://www.ford-trucks.com/forums/9...ng-d-50-a.html
I cant say with certainty that they did or didnt make the 350 4-wheel drive in that year. I would have to say they did, cause I have even seen 89 F-350 dually's with 4-wheel drive. As for donor parts, stick from 87-97.. If you have any questions, hit me up!
Old Jun 17, 2010 | 05:54 PM
  #38
Briansshop's Avatar
Briansshop
I still drop in every once in a while. Midwest,lots of good info in your thread.
Old Jun 17, 2010 | 06:10 PM
  #39
Midwest Dually
Ohh cool.. you are around! LOL! I havent seen many of the same named floating around much from the origin of this thread!
Thank ya!
Old Oct 10, 2011 | 05:15 PM
  #40
Chris72's Avatar
Chris72
I got bad news for you a dually 4x4 is almost useless in the snow it won't do much better than the stock 2wd as the truck is now.
This. My crew cab dually used to get stuck in wet grass. My SRW 1 ton digs right thru. Even when I had the 4x4 dually i got stuck alot just spinning on the top.
Old Oct 10, 2011 | 05:59 PM
  #41
fishmanndotcom's Avatar
fishmanndotcom
here is a list of truck years to look for a donor axle:
1978-79 F-350 and some F-250 (Snofighter and High GVW packages)
1986-88 F-350 with dual rear wheels (DRW)
1988-91.5 F-350 with single rear wheels (SRW)
1992-95 F-350 (all) (balljoint)
1996.5-98 F-350 (all) (balljoint)
credit:
Pirate4x4.Com - Extreme Four Wheel Drive
-cutts-
Old Apr 18, 2013 | 02:26 AM
  #42
eeespelin's Avatar
eeespelin
4wd High
i was thinking of doing a dually conversion on my 97' F-250 any tips from someone who has done one before?
Old Apr 20, 2013 | 06:14 PM
  #43
Brown Falcon's Avatar
Brown Falcon
I did the opposite to mine. Dually axle (non cab and chassis) bolts right in on the rear. If 4x4 you will need dually hubs or spacers in front.
Old May 9, 2013 | 10:28 PM
  #44
Deondre Cray's Avatar
Deondre Cray
2WD TO 4WD 7.3 EXCURSION
I WANNA COVERT MY EXCURSION SO BAD , WHAT WOULD I HAVE TO LOOK FORWARD TO? AND HOW HARD WOULD THIS BE?
Old May 15, 2013 | 02:46 PM
  #45
Brown Falcon
Not sure on the Excursion. If it is coil spring front, you might be able to swap in a '05+ front axle pretty easily since they switched to coil springs on the 4x4's that year.
