need some help asap
Old Jul 24, 2006 | 07:54 PM
ffordman46095's Avatar
ffordman46095
need some help asap
I'm looking into buying a 2001 250 7.3L the problem is the truck I am looking at starts and runs but as soon as it tries to moves it falls flat on it's face. it idles really rough, the check engine light is on and it won't pick up the rpms very fast. Holding to the floor it takes about 30 seconds to a minute for it to rev up.Could someone tell me what they think might be wrong with it.
Old Jul 24, 2006 | 07:59 PM
CAT_man_963's Avatar
CAT_man_963
My first thought is... is it blowing any smoke during any of this??
Edit: Welcome to FTE by the way
Old Jul 24, 2006 | 08:04 PM
ffordman46095
It only smokes when it revs up and when it does it is black like a diesel should be and it's about the normal amount of smoke that a diesel smokes.
Old Jul 24, 2006 | 08:08 PM
MAKO314's Avatar
MAKO314
my truck did the same thing after I blew the IC tube off. check the intercooler tubes and all the black and blue boots for splits and make sure all of the clamps are tightend to spec
Old Jul 24, 2006 | 08:09 PM
CAT_man_963
Hmm... well that says that it's getting fuel.... lets see.
If the SES light is on - that means there are codes stored, that would most likely help identify the problem... That's definitely where I would start.
It's pretty tough to say - could be something as simple as the CPS.... or could be as serious as bad injectors, or even worse....
Old Aug 7, 2006 | 02:54 PM
NChornet's Avatar
NChornet
I would guess the EBPS needs cleaning see if you have a P0470 code.
Old Aug 7, 2006 | 04:45 PM
t.j.g.'s Avatar
t.j.g.
may be a dusted turbo !
Old Aug 7, 2006 | 06:49 PM
Uzumati's Avatar
Uzumati
someone else had this problem recently and they had an exhaust brake that was stuck closed.
Old Aug 7, 2006 | 08:47 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
to go along with what amiller said, have someone stand next to the exhaust pipe, out of the way of the smoke, and see if they can hear a hissing noise from the exhaust pipe.
