ok i have a 75 f100 ranger with the 390 big block in it, it was runnin good and then all the sudden it started missin and bam shut off. so i thought hmm ran out of gas so i put gas in it and tried to restart it, it wouldnt start so i dumped gas in the carberator and nothin, then tried startin fluid nothin, the points, condensor, rotor, and cap and plug wires and plugs are brand new. its gettin fuel and theres fire to the plugs. it wont try to start unless i advance the timing alot but then it just kinda hickups for a second then goes back to tryin to start any ideas wat it could be?
Now put the breaker bar socket on the crankshaft bolt and turn it one direction or the other until you see the rotor in the dist turn a little......... stop
Now you need to reference the bar as in a circle.
Start turning the crankshaft the OTHER direction making note of how many degrees of a circle it takes before the rotor starts to move. 10*, 20*, 30*,45* etc
I have worked on trucks, where the distributor gear cotter pin had sheared. Place the harmonic balancer on Top Dead Center (TDC). Then remove the distributor cap noting the location of the number one spark plug wire in reference on the distributor housing. The rotor should be approxiamately pointing to the number one spark plug wire on the distributor cap.
Remove the distributor and verify the cotter pin on the gear, make sure the cotter pin has not sheared. Verify the gear on distributor shaft does not turn freely on shaft.
Follow these step in reverse to order for reinstallation, set timing using a timing light and to engine specifications.
Sounds like the timing chain jumped all right . Turn the engine over with the tappet cover off, until the #1 exhaust is just closing, and the intake is just opening. This is TDC, split overlap. Now check the timing marks. If they aren't lined up, the chain has jumped.
Hello, Mark here. I have a similar problem with my truck; It is a '74 f-250, 22K miles on a professionally rebuilt 390. It had been running well except a occasional miss when stopped in drive, started up fine until 2 days ago. It cranked long, then would start, then would not start at all. I checked coil spark...OK... then put the coil wire back on and it started fine again for 2 days. I did a much needed tune-up...points, condensor, rotor cap, wires, even coil. The firing order is correct, the point gap is .017, the plugs are Bosh Platinum pre-gapped @ .044.
I did the timing slop test...the rotor moves almost immediately.
I have spark at the coil and plugs.
I have gas going to the very new 4BBL Edelbrock Performer carb.
The truck ran fine and stared fine until I did the tune-up. Now it just cranks.
It is always best to make your won thread reragrding your topic even if it is the same.
*Look for : Post New Topic*
The gist of any Thread should be centered on the original post of the thread otherwise we will be all over the pace answered the wrong person..it gets confusing.
Maybe a Moderator ( ERIC !) will move your post to have its own thread so we can keep everything in order.
I thought it was always best to line the rotor up with something on the engine (Like a bolt) as opposed to something on the distributor which is being removed anyway ?
The position of the vacuum advance has to be referenced as well.
