Offroad & 4x4
Trail disaster!
Old Jul 23, 2006 | 09:23 PM
MBBFord's Avatar
MBBFord
Unhappy Trail disaster!
Well I went mud ridding today, and to say the least bad things happend.
I tried going in a hole, that didn't work.
When I couldn't see my tires any more, I knew I was in trouble, when I saw the slush/mud/water coming in, I knew I was screwed.
I got it out ok, but the 4wd wasn't engageing after, I started driveing to turn it around then the 4wd caught and my front driveshaft broke, which then started flapping around and Fu**ed up my shift linkage, and hit my transmission pan dinting it causing a leak.
After that I took it out of 4wd and unlocked the hubs, started driveing throught the field and hit a hole(grass covered) going about 20mph, and my coil spring turned in to a slinky gone bad. They were so twisted I don't know how they didn't shoot out. The shocks were holding up all the weight up front, and later my drivers side spring fell out.
Thinks didn't go good...
Any suggestions on fixes?
Old Jul 23, 2006 | 09:37 PM
MBBFord's Avatar
MBBFord
Well, for the front driveshaft it broke off where the CV meets the driveshaft(CV broke where the u joint is held on at). Also 1330 just isn't working... What should I upgrade too? 1350? OX, CTM(I think that's the company) or somthing similar?
I have a trasmission pan I could use to replace the leaking one(should I just put the old one back on, or try and fix the chrome one I put on a little while back)?
Coil springs: I don't know what to do I'm going to mount them back like the were for now, but is there anything else I can do that holds them better or somthing.
Sorry no pics(just with it on the trailer before).... I have alittle film that I will try and get on here, but it is just a discrace and isn't too good anyway. I couldn't make my self take pics of the Bronco when it was dead in the field... Sitting there almost on the tires with twisted to ***** spring, but some how the shocks held it.
I'm depressed.... All I had to do the rest of the day was think of the madness, and watch a bunch of chevys go through the mud(of coarse not where I went though).
Old Jul 23, 2006 | 09:42 PM
T18skyguy's Avatar
T18skyguy
It really hurts right now but a couple years from now you'll laugh when you tell the story. Id go right to the boneyard and scarf some parts.
chrono4's Avatar
chrono4
wow, sounds crappy..............um i guess it could have been worse
Old Jul 23, 2006 | 09:55 PM
captain p4's Avatar
captain p4
wow sorry to hear about that bro.. but just look at it as an opportunity to make it better and stronger for next time!
Old Jul 24, 2006 | 05:18 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
sounds about like a normal off road trip to me
Old Jul 24, 2006 | 08:58 AM
rebocardo's Avatar
rebocardo
If the hole is on the side, it would be a perfect time to add
a welded on bung for a drain. You can get the screw in ones, though
I think the welded in ones are better if you have a MIG.
I like having one on my truck, makes a fluid change every
20k or less painless.
If you have manual hubs and manual transfer case, how did
the 4x4 fail ???
At this point, I would change ALL the fluids in the vehicle and
lube the front end until new grease flowed EXCEPT on the balljoints.
I suspect the coils went bad because the axle was stuck and being pulled out they got over extended. I would suspect the shocks and rubber brake lines (one to front axle) probably need to be replaced too.
If you put limiter straps on your axles, ESPECIALLY a coil spring axle, you can avoid this in the future. I like to use cable because I can make it an exact length and its cheap.
You can make coil retainers or just hunt down upper ones from say an AWD Aerostar, that can easily be bolted in place with a 1/4" bolt. On the lower part of the coil, depending on the vehicle, you can just use muffler clamps with a piece of 1/4 steel.
Old Jul 24, 2006 | 10:46 AM
MBBFord's Avatar
MBBFord
captin p4, I'll try to at least put a stronger driveshaft, but not sure how beefy I should go(without going broke).
KO76, my normal trip usually consist of me fixing the inner plastic fender and half the time a u joint.
Old Jul 24, 2006 | 10:56 AM
MBBFord's Avatar
MBBFord
the 4x4 fail ???
Well the 4x4 quite engageing b/c of the horrible shift linkage design on the NP203. I'm guessing it just sliped out, and after I got pulled out, I started going and it magically caught, and broke my front driveshaft.
Would a sway bar help limit the flex enough to wear I wouldn't need to put a limiting strap?
I'll be replacing the front shocks, but the SS extended brake lines I installed should still be ok.
I'll try replaceing fluid after I get the coil springs back in place.
KO, a while back you mentioned NP205s had 2 different kinds of adapters between the case and transmission. One short one(same length as 203), and a long one. Well the long one won't work for me unless I get a longer tail shaft, which I don't want to do, so were could I find a short 205 adapter(any particular truck)?
Old Jul 25, 2006 | 12:32 PM
rebocardo's Avatar
rebocardo
> limiting strap?
Yes, but, it limits it to both sides without allowing the axle to pivot and drop on one side to put traction to the ground. A pull that broke your springs will break a sway bar too because the link is the weakest link. Pretty hard to break 1/4 cable or even to stretch it if you use three clamps on each end.
Old Jul 25, 2006 | 01:24 PM
MBBFord's Avatar
MBBFord
What do you connect the cable to?
I have a pretty long thick piece of cable I could use, but what would I connect it to on the axle?, and then just bolt it to the frame(how would I connect anything boltable to the cable,clamps)?
Thanks for any help.
Old Jul 25, 2006 | 01:40 PM
chrono4's Avatar
chrono4
you could just weld a eyelet to the housing, or you could go ghetto and just wrap it arround andhope it doesnt slide. on the frame side, drill a hole and use an eye bolt up there.
Old Jul 25, 2006 | 07:34 PM
ivanribic's Avatar
ivanribic
You used the word "disaster" in the title and you didn't even roll the truck. Weeeaaaak.
Cable or straps will save those front springs and your shocks too. Make sure you use one on each side about under the frame rather than just 1 in the center like I've seen some tools do.
Good call on the tranny drain bung Rebo. I would have just replaced the pan but that's not a bad idea at all.
Old Jul 25, 2006 | 08:30 PM
chrono4's Avatar
chrono4
ivan i think the thing with just one strap, it it wont really limit flex, just over all downtravel keeping u joints from binding and maxign out drive shafts. it can still flex out though.
Old Jul 25, 2006 | 08:51 PM
MBBFord's Avatar
MBBFord
Wink
Sorry Ivan, breaking my front driveshaft, makeing my front springs look like a slinky gone bad, and busting my trasmission pan, and getting really stuck twice was all just one really big disapointment.....
I'll see what I can do with some cable and try and figure out a way to attach it to my axle(I'd don't want to be ghetto and just wrap it around ). If possible, I'd like as many ideas as possible on this, b/c I'm kind of clueless on connection points that WILL hold up.
I was looking at the transmission pan, and saw it wasn't as bad as I thought it was. I might just drop it, and half a** get the dent out(no busted seams or holes anywhere), and just put a new gasket. All it looks like is the gasket got messed up. This drain pan already has a drain plug in it, so I should be good to go after I seal it back up.
Thanks for all the help so for guys.
