LED Dash lights
Old Jul 23, 2006 | 08:56 PM
dirtyfergie's Avatar
dirtyfergie
LED Dash lights
Hey everyone just wondering if anyone has ever put Led bulbs (149) into the stock dash on a 1986 f-250 diesel 4x4 auto? They should match the same just wondering what the light output would be and if I would have to bore out the mounting holes. Any help would make my day a lot better. I found these bulbs online they look like they would work. they sure would be better than my stock bulbs I can't see anything at night.
Super Bright
Old Jul 23, 2006 | 10:13 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Here's some threads about the Dashlights to help ypu out. This question gets asked quite often.
https://www.ford-trucks.com/forums/s...d.php?t=441008
https://www.ford-trucks.com/forums/s...d.php?t=416975
https://www.ford-trucks.com/forums/s...d.php?t=432590
Old Jul 24, 2006 | 08:47 PM
swamp fox's Avatar
swamp fox
For someone who has done this before... how many bulbs are in there? I want to replace them all and order the right number of bulbs! One side of my instrument cluster is completely dark, the other side is terribly dim, and some bright LED's are just what the doctor ordered.
Old Jul 24, 2006 | 11:14 PM
81-F-150-Explorer
There are 5 for cluster ilumination.
There can also be up to seven for Warning Indicators.. Turn Signal, Brake, High Beam etc... but may only be 5 depending on year model, 2x4 or 4x4, etc...
The bulbs are standard #194. Sounds like a few are burned out in your cluster.
If you get a LED that fits a #194 socket, you should be fine.
However, if you read the threads posted, this might not be such a good idea cause you cannot dim the LEDs with the headlamp switch. You will get full brightness or off.
Something to consider.
Old Jul 25, 2006 | 01:17 PM
Nathane's Avatar
Nathane
Might wanna hold of on the LED's...
I've seen melted dashes in the junkyards, which to me seems like soembody put a higher wattage bulb in.
From the factory, they had acceptabal lighting... Why change that to something that could ruin your dash?
whatever you do, good luck
~Nate
Old Jul 25, 2006 | 01:20 PM
swamp fox's Avatar
swamp fox
LED lights run very cool. Why do you think they would melt the dash? They are much cooler (and brighter) than OEM. The OEM lighting was actually not very good (to me, not acceptable... YMMV). Instrumentation should be bright and readable without compromising your night vision, IMO.
I don't mind losing the dimmer since I never use it anyway. My dash lights on all my cars have always been set to full bright. As long as it is a colored light and not white, your night vision can hold up.
I'm working up a web site for my truck to log all of these changes so hopefully they will be of use to others.
Old Jul 25, 2006 | 02:13 PM
SuperSnake's Avatar
SuperSnake
Great it will be a help to me for sure.
Luke76
87
Nov 1, 2021 08:10 PM
adbscu
Dec 11, 2015 12:35 PM
FL SuperDuty
Jan 13, 2015 05:44 PM
Ford_Fan1
Dec 30, 2014 09:35 AM
