Shorten rod mod question
Old Jul 23, 2006 | 05:33 PM
Lance_I's Avatar
Lance_I
Question Please Help! Shorten rod mod question
I heard on here that you are supposed to blow air through the wastegate to get it to extend but i've gotta question. I did that but it looks to me that the wastegate can't open at all now. I'm sure it needs a little room to move or at least it seems it does. Anybody know how much to screw it down? Right now mines almost all the way screwed in to where I can just barely get it over the pin with the air compressor.
Old Jul 23, 2006 | 06:14 PM
Kwikkordead's Avatar
Kwikkordead
It's already set way too tight. I can tell you from experimentation and personal experience that with a stock turbo, just having your boost go way up doesn't necessarily mean you are making more power. I cranked my WG control rod all the way down in the beginning and was gleefully watching the boost nearly hit the peg at 30 PSI when I would get on it hard. But I was also left with the feeling that the truck would pull harder if I shifted early and kept the rpm below 2500.
Fast forward. I've reset my wastegate to 10-12 psi and have now found that the engine revs MUCH more freely above 2500 rpm and pulls a lot stronger at that rpm as well with no power loss due to now only making 20 psi. If I hook up the trailer the boost will still climb up to 26, but now I am much more comfortable with that because I know also that the drive pressure is much lower than it used to be, which is a lot easier on both the engine and the turbo bearings.
Old Jul 24, 2006 | 07:16 AM
PSNut's Avatar
PSNut
A good combo is having a larger exhaust housing like my 1.00A/R. It relieves surge(none) revs freely and keeps drive pressure more evenly balnced on bearings.
Nut
Old Oct 31, 2006 | 11:16 PM
PowerStrokeMe's Avatar
PowerStrokeMe
PS...where did you get that exhaust housing?
Kwik...did you adjust your rod on the truck or did you take the wastegate off the EBPV and slot it is held onto the turbo? How do you know what relief boost setting you adjust the rod to?
Old Nov 1, 2006 | 06:14 AM
Kwikkordead
It requires a pressure guage to adjust the control rod. Ford spec is to have the lever just begin to move at 5 psi. I set mine to around 10-12 psi. With that setting I still get good spool up and good pressure control for the most part. The only time that it goes over pressure now is when I am pulling the trailer up the mountain pass at WOT. I seriously doubt that setting the control rod to 5 psi will cure that due to the fact that there is no WG passage on the left bank. All the pressure relief is done on the right bank.
PSNut, is your 1.0 the wastegate or non-WG version and how much weight do you pull at times? And how high does the boost go and what sort of tunes are you running if not stock?
Old Nov 1, 2006 | 04:38 PM
PSNut's Avatar
PSNut
Got it from LIPD out of Long Island,New York LINK $400 w/free ship.
Don't think they carry it anymore.
Bean's carries them now: LINK (scroll down for wastegated version 1.00A/R
housing)
Wastegated version. 9K lbs camper. Max boost = 26psi. DP tune is 80hp/150ft lb econo.
Old Nov 1, 2006 | 05:00 PM
Kwikkordead
Thank you PSNut.
Pitcrw6
Sep 8, 2012 12:15 PM
plgebbia
46
Jan 17, 2011 05:23 PM
hucka1a
May 31, 2008 01:14 PM
smoky_diesel
Oct 3, 2007 05:02 PM
David85
23
Mar 9, 2007 12:45 PM
