Timing Cover Question
Old Nov 25, 2002 | 10:17 PM
rayray2k22002's Avatar
rayray2k22002
Hi all
61 292v8
I pulled my radiator to be rebuilt and decided to paint my waterpump and timing cover....I can't get the timing cover off....
Whats the trick , I pulled all bolts, do i need to drop oil pan?
or do i need to take out the front motor mount?
What gives
Old Nov 26, 2002 | 08:14 PM
Rosati's Avatar
Rosati
You'll need to remove the front oil pan bolts, damper, front engine mount and water pump to remove the timing cover. I suggest that since your there, check your timing chain. If deflection is more than 3/8", replace both gears and chain. Also be sure to replace your damper oil seal too.
Old Nov 27, 2002 | 08:14 AM
jcs1966's Avatar
jcs1966
On my timing cover (352) the pointer doesnt stick out far enough to align with the pully wheel so how do you set the timing? (What is the correct timing?)
Old Nov 30, 2002 | 05:12 PM
yenima38's Avatar
yenima38
I Also would like to know what the correct timing is, and how you set it.
[br] [br]Randy - Just another Ford Lover
Old Nov 30, 2002 | 07:26 PM
blackhawk 829's Avatar
blackhawk 829
beefmalone
Dec 2, 2014 10:44 AM
T18skyguy
Jun 5, 2010 06:50 PM
kjett
Jun 21, 2007 07:02 PM
tonedog
Jun 26, 2003 12:18 AM
ZRX61
Dec 26, 2002 07:27 PM
