Tailgate won't close
Old Jul 23, 2006 | 01:42 AM
skipper12's Avatar
skipper12
Just noticed my 2000 Ranger XL tailgate won't latch.when i move the handle both latches move in and out but not enough to get over the clip.tomorrow i'll spray some wd on them and see if that works, or is there something else i need to do?
Old Jul 23, 2006 | 03:30 AM
FTE Trigger's Avatar
FTE Trigger
Wink
The latches on my (old) '99 once had a problem too.
I actually went into the access panel on the inside of the tailgate and "Degreased" the entire linkage/latch mechanism. Then went back with Spray-on Graphite and Spray-on White Lithium grease.
Then I bumped that particular procedure into my PM catagory for a frequency of every 3-mos.
A quick Wd-40 spray-on may only allow more dirt grease to collect in the latch/linkage areas. I would'nt skimp on it... You could really put some unnecessary stress on the internal linkages & handle, if that dirt and old grease builds up "too much".
Old Jul 23, 2006 | 05:21 PM
john112deere's Avatar
john112deere
Yep.
I just spent 45 minutes or so cleaning, degreasing, and lubricating the latch mechanism on a friends F-350 last week. I took off the access panel, blew the dust out with compressed air, then degreased and lubricated everything that moves. It latches and unlatches MUCH easier now.
Old Jul 23, 2006 | 05:55 PM
Greywolf's Avatar
Greywolf
Mine didn't budge.
I had to work it from side to side to get it open, but then I treated it with lithium spray and it hasn't stuck since.
Old Jul 24, 2006 | 02:44 AM
natebaker's Avatar
natebaker
My gate did that once on my 99. After I slammed it and goosed the handle a little, I haven't had any more problems since, and this was 6 months ago.
Old Jul 26, 2006 | 02:11 PM
skipper12's Avatar
skipper12
Turns out i had to grind some metal off the latch assembly because the latch mechanism wasn't pushing far enough into the strikers for the latch to catch.I think the strikers needed adjusted but i didn't have the special star wrench to loosen them so the grinder got a workout and it works fine now.
Old Jul 27, 2006 | 08:50 PM
frdrngrlvr's Avatar
frdrngrlvr
there is a "c" clip that is supposed to present that is around the pin that holds both levers together. they do break or pop off. i just did this last week and also adjusted the threaded shaft to make opening a bit easier.
RancherJV
Sep 25, 2016 07:32 PM
Wally Moore
1978 - 1996 Big Bronco
Nov 5, 2012 04:07 PM
piratius
Jun 6, 2012 07:00 PM
gharris54
Jan 8, 2012 09:22 PM
jasond5150
Aug 6, 2008 09:48 PM
