Paint in the threads! Any options?
Old Jul 22, 2006 | 09:59 PM
jhard527's Avatar
jhard527
OK. I took my in-the-cab gas tank to have the inside acid washed and coated.When I got there, my baby blue gas tank had been painted black! Why? Because they paint everything black, no extra charge! Well, the gas sending unit bolt threads are now full of paint. Does anyone know what would be the best way to remove the paint without ruining the inside coating?
Old Jul 22, 2006 | 10:58 PM
66 twin i's Avatar
66 twin i
A tap and die might work but i am not sure.
Old Jul 23, 2006 | 01:08 AM
jake00's Avatar
jake00
I agree, Tap the threads
Old Jul 30, 2006 | 06:52 AM
cujo8's Avatar
cujo8
The coating I used to seal the inside of my tank is polymer that is quite solvent resistant, since it is meant to be in constant contact with gasoline. I would wet a Q-tip with laquer thinner and clean the threads carfully.
Old Jul 30, 2006 | 09:29 AM
LarryA's Avatar
LarryA
Clean out the threads with a good sharp tap. If you have access to one, a Sprial Aluminum tap (made to tap aluminum and soft metals) will work better than a stardard tap but either should do the job. Be carefull you don't cross thread or jam and break the tap. The Assembler for what I run on my CNC job, cleans PVC plastic coating out of screw hole threads every day using a tap and rarely ever has and problems (this is a coating similar to the way powder coating is done but the part is heated then dipped in a powdered PCV plastic. It fills threads rather bad and is much thicker than paint.
Old Jul 30, 2006 | 09:41 AM
fordpilot's Avatar
fordpilot
Put the gas tank in your wifes car. Drive to the place that
did the work. Show them the problem. Show them your
cousin Quido's picture. Case closed.
If they are kind of perplexed, show them a roll of masking tape
and explain what it is used for.
Old Aug 1, 2006 | 05:15 PM
chrono4's Avatar
chrono4
x2 right here.
Old Aug 3, 2006 | 10:41 PM
hot1958's Avatar
hot1958
a tap is your best bet.
