Sponsored by: Real Truck
new power stroke owner
Old Jul 22, 2006 | 07:56 PM
avidbow's Avatar
avidbow
Hello all... i just bought an 01 f250 s.d. 4x4 diesel lariot trim. Awsome truck!! I've had fords most of my life but never a diesel. If i ask simple questions, bear with me!! Thanks, Jeff
Old Jul 22, 2006 | 09:13 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Welcome to the site!!!!
Old Jul 22, 2006 | 09:16 PM
stewcon's Avatar
stewcon
Welcome aboard. Just ask a question and the very knowledgeable members will get you an answer.
Old Jul 22, 2006 | 09:54 PM
ryaneverk2's Avatar
ryaneverk2
Welcome, and good choice!
Check out the 7.3L PSD section a ways down on the main forums list... lots of good discussion about your engine in there. Also, check out the Common Mods sticky in that section. Finish reading that and you'll be an expert.
Old Jul 22, 2006 | 10:56 PM
avidbow's Avatar
avidbow
Smile thanks
Thanks for the replies. I'm trying to get thru this site and it seems confusing! Anyway, i've been reading some mags, and never having owned a diesel before, saw that there is ALOT to learn!! To that end, what can i do to get the motor to breathe easier and exit the truck easier? Anyone have a favorite brand or result to share? All i really want to do it make the motor as efficiently as possible because i travel alot for my job and look to the diesel motor to last far longer than a gas one. Jeff
Old Jul 22, 2006 | 11:34 PM
ryaneverk2's Avatar
ryaneverk2
Jeff, go here to the 7.3L section, and make a new thread with whatever you'd like to talk or learn about:
https://www.ford-trucks.com/forums/f...splay.php?f=31
Also, try out the search feature, on the blue bar at the top of the screen... can be very handy when looking for commonly-discussed topics.
Old Jul 22, 2006 | 11:51 PM
21M's Avatar
21M
New 7.3L owner?--do yourself a favor and use the search feature to educate yourself on the CPS (camshaft position sensor). When mine went out (keep your truck long enough and yours will go out too), it drove me nuts trying to figure it out until I stumbled onto this AWESOME site. I even dropped the tank thinking that I might have trash or something in it. Had I heard about the symptoms ahead of time, I would have had it fixed in a snap!
Old Jul 23, 2006 | 12:13 AM
GroverDill's Avatar
GroverDill
Welcome, I am also a new PSD owner, first diesel also.
Old Jul 23, 2006 | 10:50 AM
chucknmesa's Avatar
chucknmesa
New Super Duty 6.0 4x4 owner
I just became the owner of an 06 F250 Super Duty 4x4 with the awesome 6.0 power plant. Never owned a 4x4 or a diesel before. Looking forward to some off-roading adventures ahead. I'm interested in getting more mpg and hp out of this unit. Any suggestions?
Old Jul 23, 2006 | 04:24 PM
kaipo's Avatar
kaipo
Welcome to FTE like I always say, this site will get addicting and it's very very helpful. I learned alot from here and still learnig. It's Awesome!
Aloha,
Kaipo
Old Jul 28, 2006 | 01:17 AM
Billfseries3's Avatar
Billfseries3
Hi, I have just test drove a 2003 F350 diesel 6.0L. Boy does the truck move. I am considering replacing my Ram 2500 V10 8.0L (mpg maybe 10 if lucky) with this truck. It burns gas like there is no tomorrow. Have some concerns before buying one though, as they cost more of a premium then gas engines. I have fixed gas, but not diesel, and never owned a diesel. Hope someone can answer a few questions below.
1). What is considered high milliage for 2003 in a diesel?
2). Does limited slip differential makes a difference on a 4 X 4?
3). How long will these engines last?
4). Is it easier to fix, then gas engines?
5). Are these engines expensive to fix? Are they as expensive as foriegn parts?
Old Jul 28, 2006 | 08:58 AM
paulkeith's Avatar
paulkeith
i'll field that limited slip question...
with an open differential, 1 wheel is guaranteed to get power. so, as soon as one wheel loses traction, it'll start spinning. in effect, you're guaranteed 1wd per axle.
if you're in 4H or 4L, both axles are getting power, but at any time, no more than 2 tires are guaranteed to be spinning....which are probably gonig to be the ones on ice, mud, or in the air.
with a limited slip, you're *pretty*much guaranteed both wheels per axle will spin at equal speeds, giving you guaranteed 4wd. they only allow tires to rotate at different speeds in situations like a turn on pavement.
hth
Paul
johnsonjf
Jul 24, 2013 09:04 PM
jmorgan2622
Jan 18, 2010 07:43 PM
jefftino
General Diesel Discussion
May 10, 2006 06:03 PM
jcab
Nov 8, 2004 09:10 PM
Jeff Van Housen
Jan 25, 2002 08:23 AM
