95 windstar re-starting problems
Old Jul 22, 2006 | 06:17 PM
twin66's Avatar
twin66
Hello, I have a question for the van guros out there.
Long story short, my dad is a mechanic and has come across a problem he was not seen before. On a clients 95 windstar, (I don't know anything else about it) It will start when attempted, BUT once it hasd been shut off, the battery must be disconnected, and then re-connected before it will run again.
Has anyone come across this before? Any ideas? Would this be a bad module?
Any ideas would be appreciated, and I will post more info if I get more.
Thanks, Craig
Old Aug 12, 2006 | 10:43 AM
amish77's Avatar
amish77
so what does it do when it won't start, are we talking dead stick, or turning over and not catching, or what?
Old Aug 12, 2006 | 05:52 PM
twin66's Avatar
twin66
It turns over, but will not fire, until the battery is disconnected and then reconnected, any ideas?
Old Aug 12, 2006 | 06:13 PM
sheebeehuh's Avatar
sheebeehuh
It's a long-shot but I'd check the emergency fuel cutoff switch and related circuitry. Commonly called a rollover switch, it's designed to disable the fuel system in the event of a vehicle rollover to reduce the likelyhood of fire.
Old Aug 14, 2006 | 07:57 AM
amish77's Avatar
amish77
you can also check for spark when it doesn't fire. check it at the plugs, not the coil.
Old Aug 14, 2006 | 03:36 PM
twin66's Avatar
twin66
Hmmm, never thought about the rollover switch, will check and reply with findings. Thanks guys
Old Aug 14, 2006 | 04:01 PM
den25's Avatar
den25
ecu
all kind of staff is possible when ECU is bad. I had a problem on 1994 Escort Wagon - after 40 minutes of driving engine would start to miss and after a minute would stop completely. After few minutes could be restarted; but would work 5-10 seconds and dye again. After that, there was like a horror movie: if try to start or simply keep the igntion ON, all (!!!) the lights on dash board would start to blink, various relays all around the car would arratically click all at once. Scary! Tell you guys, I would not be surprized if the blood would start to drip from the roof.
Turned out to be faulty ECU, was confurmed by heating it up with heat gun and later swapping ECU from identical car.
den25
frederic
Aerostar
Sep 24, 2007 09:50 AM
dadstoys2
Aug 24, 2003 10:24 PM
73Thing
May 8, 2003 05:52 AM
73Thing
May 5, 2003 11:57 PM
