Sponsored by: Auxito
Which axle?
Old Jul 21, 2006 | 06:43 AM
fordguy4life's Avatar
fordguy4life
Which axle?
Which axle? I have a '99 F150 with an axle leak. The cover of the housing is leaking and needs to be replaced. I have the new cover and 75/140 synthetic. I have the axle with the 9.35 ring gear. None of the tags have any of the codes that were in the FAQ's on this subject. This isn't the original axle on the truck. My question is, do I have a L/S axle that needs the friction modifier additive?
Old Jul 21, 2006 | 10:28 AM
skilife17's Avatar
skilife17
Look at your door jam sticker under axle and there will either be a letter and a number or two numbers. Here is a link to the door sticker decoder hope it helps you out.
https://www.ford-trucks.com/article/...r_Decoder.html
Old Jul 21, 2006 | 10:38 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
If you have the 5.4L, then you have the 9.75" rear axle
Old Jul 21, 2006 | 11:22 AM
LxMan1's Avatar
LxMan1
Does the rear end still have a tag bolted to the cover bolt? It should have the code on it. Usually on the bottom line, the first few digits have the axle ratio. Something like 3 55 9 75 would be a 9.75" gear 3.55 open. It may also have 3L55 which would be 3.55 LS and would need the additive.
Old Jul 23, 2006 | 08:33 AM
fordguy4life
Thanks Lx. Looks like the 3.73 L/S.
Toyman
1978 - 1996 Big Bronco
Jan 28, 2015 09:13 AM
Vee
Oct 14, 2008 07:23 AM
brunot
May 1, 2006 04:06 PM
MrBadExample
Mar 3, 2005 11:09 PM
Jared Putz
17
Nov 10, 2003 03:19 PM
