Sponsored by: Auxito
a/c problem
Old Jul 20, 2006 | 07:28 PM
fordman1000's Avatar
fordman1000
a/c problem
I have a 97 4.2 f150 the a/c works perfect but causes the truck to miss or hesitate ..with a/c off runs fine..friend told me i need to re-flash the computer..rather a dealer needs to..any ideas me and my wallet would appreciate it
Old Jul 20, 2006 | 08:25 PM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
Does the problem only happen at idle or when driving it too?
Does it idle ok with the A/C off?
How many miles on the spark plugs and fuel filter?
Old Jul 21, 2006 | 05:42 AM
fordman1000
the problem is more noticable when driving and especially at constant speed..I did notice the idle doesnt change when I turn a/c on and off. All of the basics have been changed...plugs,filters,etc. If i was to descibe how it feels when driving its almost like the clutch is slipping,,even though its new..p.sp thanks for your response
Old Jul 21, 2006 | 11:30 AM
LxMan1's Avatar
LxMan1
Is it low on charge causing the compressor to short cycle on and off?
Old Jul 21, 2006 | 12:42 PM
fordman1000
no the a/c charge is fine
Old Jul 24, 2006 | 08:33 PM
Blackbeauty97's Avatar
Blackbeauty97
I had a car where the a/c compressor was going. I don't know if it was a clutch or a bearing??? However, it would kind of lock up and cause the engine / power to surge.
Do you hear any squeels/ rattles???
Old Jul 25, 2006 | 06:42 AM
fordman1000
thanks for the response,its much more pronounced than a compressor cycling..but to answer the question ,no it doesnt make any kind of noise and it stays on while running..the whole truck stutters when it happens like I said before it feels like a strong miss ..I think it might be in the PCM or the IAC but those are my best quesses
Old Jul 26, 2006 | 05:28 PM
Blackbeauty97
Well, on the old cars....when the a/c was turned on a solenoid was used to increase the throttle.
Your probably on the right track with the computer. I'm not too sure what sensors are on there but a bad sensor could be a problem.
Looking in a electrical schematic from a Haynes manual.
There is a "Powertrain Module";a/c clutch cycling pressure switch;a/c pressure cutoff switch....to name a few...
I'm not an expert, but maybe "Google" those parts and see if they would play a part in your problem?
contactjesse
Mar 7, 2016 12:23 PM
firebug
Jul 31, 2011 08:51 PM
Project_dog
Jun 14, 2010 09:27 PM
vent
1983 - 2012 Ranger & B-Series
Jun 4, 2010 12:51 PM
Ferrite
May 26, 2002 09:58 AM
