Sponsored by: Real Truck
Front end problems in left or right turns
Old Jul 19, 2006 | 09:52 AM
Tact's Avatar
Tact
I have a '03 F250, diesel, 4x4, with 47K miles. When I make sharp left or right turns I feel the tires "hop". I don't fell this while driving straight, only in sharp turns. Could this be the differential clutches needing servicing with only 47K miles? I wonder if adding any friction modifier alone would help or does anyone else have any thoughts?
BTW all ball joints and link ends appear OK.
Old Jul 19, 2006 | 10:14 AM
FortFord's Avatar
FortFord
Check and see if both of your front hubs are fully disegaging. This was happening to my truck just before I swapped to manual hubs.
Old Jul 19, 2006 | 10:39 AM
Tact's Avatar
Tact
This is happening in two wheel drive.
Old Jul 19, 2006 | 12:05 PM
DetailerDave's Avatar
DetailerDave
One or both hubs could still be locked, causing what you are feeling. Verify that they are unlocked by reaching under the truck and turning the axles by hand.
Do you have ESOF or manual hubs?
Old Jul 19, 2006 | 12:28 PM
Tact's Avatar
Tact
Mine are electric locking hubs, not manual.
Old Jul 19, 2006 | 01:14 PM
alfama351's Avatar
alfama351
I just went through this.
Jack up the front of your truck, use jack stands and turn spin the wheels, if either one or both axles turn than your hubs are not unlocking.
I'll find the thread on mine and post it.
Old Jul 19, 2006 | 01:21 PM
alfama351's Avatar
alfama351
This is the thread from when mine went bad.
https://www.ford-trucks.com/forums/s...d.php?t=505303
This is a great write up by BFR250SD on one of the options to fix it.
https://www.ford-trucks.com/forums/s...d.php?t=467258
Old Jul 19, 2006 | 03:11 PM
FortyFords's Avatar
FortyFords
Your hubs are actuated by vacuum ,the transfercase is a electric shift motor.
Before jacking up follow the persons advice try to turn the axles behind the knucle to see if the are free .If not ,could be 2 problems hubs are binding or your front needle bearings are going away and need replaced.
Rich
handymanhobbs
Dec 3, 2015 10:55 AM
Agent99
Nov 9, 2014 08:33 AM
expo1
13
Nov 21, 2006 03:45 PM
thooor
2004 - 2008 F150
Jan 16, 2006 10:44 AM
Maynster
Jan 16, 2005 09:53 PM
