DTC code p0487
Old Jul 18, 2006 | 11:35 PM
smikhail's Avatar
smikhail
DTC code p0487
Newbee here anyone know or how to get rid or dig. the P0487 My Bully dog outlook will not del. and also has a P 1000 code. if some one knows what to d please help me out.
Removed by Admin: Please review the Guidelines about business in the forums if you are not a sponsor
Thank for any help
Old Jul 19, 2006 | 05:30 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jul 19, 2006 | 08:11 AM
Maxium4x4's Avatar
Maxium4x4
I need glasses, I read the wrong code on the 487......not 478
P1000 OBD System Readiness Test not complete, Drive cycle not complete. Anytime you unhook the battery this will appear.
Welcome to FTE these guys got you covered.....unhook your EGR?
Old Jul 19, 2006 | 08:14 AM
tvsjr's Avatar
tvsjr
P0487 is "Exhaust Gas Recirculation Throttle Position Control Circuit". Sounds like you have an EGR fault to deal with.
P1000 is the adaptive relearn code. It'll go away on its own after driving the truck for awhile and letting the PCM relearn driving behavior and ambient conditions.
Old Jul 19, 2006 | 08:24 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Did you disconnect the EGR? Possible reason for code.
Old Jul 19, 2006 | 09:15 AM
smikhail's Avatar
smikhail
i did diconnect the egr and the 0487 code went away and came back on in less than 5 min they i also got the egr code
Old Jul 19, 2006 | 09:24 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Insure it is plugged back in and run it for at least 10-20 miles...it should reset and the code should go away....Late 05 and newer 6.0's won't let you remove the plug without getting getting the code.
Old Jul 19, 2006 | 10:38 AM
kw5413's Avatar
kw5413
Welcome to FTE and the 6.0 forum smikhail
When you get a chance you might want to cruise over to our Tech Folder for some great 6.0 info.
https://www.ford-trucks.com/forums/showthread.php?t=303583
Please take a few moments to read our site guidelines as well.
https://www.ford-trucks.com/guidelines.html
Your EGR Valve likely does not close all the way due to carbon / soot build up. Probably why when you unplugged it you got little to no benefit. Plug it in and take it to the dealer.
drolens
Apr 13, 2016 02:54 AM
Tcautry
Apr 11, 2016 03:31 PM
05 f250 6 inch lift
Aug 1, 2011 08:41 PM
chrisbraziel
Sep 19, 2010 07:15 PM
kuma
Feb 7, 2010 09:47 AM
