dtc code p0487 and p1000
Old Jan 31, 2007 | 08:13 PM
kuma's Avatar
kuma
I have a 2006 6.0 and trip dog with monitor drive pretty easy any help thanks
Old Jan 31, 2007 | 08:27 PM
18vtx00's Avatar
18vtx00
i can look tommorrow about the po487, but the p100 means the pcm has not cleared all monitors yet because of a pending dtc.
Old Jan 31, 2007 | 08:32 PM
jim6liter's Avatar
jim6liter
p-0487 = EGR Trouble
Old Jan 31, 2007 | 09:06 PM
Fordtech1's Avatar
Fordtech1
P0487 ? or P0478, EP, VGT concern?
Old Feb 2, 2007 | 11:05 AM
kuma's Avatar
kuma
I disconnected the batteries for about 30 mins then reconnected them, code p1000 ,and now code p0406 appear and p0487 any help...........thanks
Old Feb 2, 2007 | 12:07 PM
BowTieHatr's Avatar
BowTieHatr
well i have no idea where p0487 is coming from, i cannot find anything on it. p0406 tells me you have the egr unplugged.
Old Feb 2, 2007 | 08:36 PM
jim6liter's Avatar
jim6liter
The Superchips DTC book says p0487 = EGR throttle pos ctrl circ,Whatever that means.Hope this helps.
Old Feb 2, 2007 | 08:58 PM
Fordtech1's Avatar
Fordtech1
Possible causes:
EGRTP actuator circuits
EGRTP actuator
PCM
Key off.
Disconnect the charge air cooler tube from the throttle body.
Key on, engine off.
The PCM will activate the EGRTP actuator and perform a full sweep of the throttle plate for each key cycle with the IAT temperature greater than 0°C (32°F).
Observe the throttle plate for movement, it may be stuck and the PCM doesn't register a voltage change.
Hope this helps>
Old Feb 2, 2007 | 10:09 PM
BowTieHatr's Avatar
BowTieHatr
well an 06 doesnt have a egr throttle plate.
Old Feb 2, 2007 | 10:12 PM
Fordtech1's Avatar
Fordtech1
2006 PCED doesn't list p0487 either, maybe a programming glitch?
Old Feb 6, 2010 | 07:37 AM
Borstmayer's Avatar
Borstmayer
same p0487 code
I have same code p0487 on my 05 6.0 deisel.I also have the Bully Dog triple dog.Has anyone figured out what this means or how to get rid of it yet.Please help as ford does not even know what it is.My diesel shop also does not know what it means.
Thanks
Old Feb 6, 2010 | 07:54 AM
tex25025's Avatar
tex25025
Thanks
The only thing I'm coming up with is Exhaust Pressure Control Valve High.
Old Feb 6, 2010 | 12:12 PM
cheezit's Avatar
cheezit
the p0487 is cuased by a programer in all the trucks without a throttle blade. Or so that has been my findings up to date.
Old Feb 7, 2010 | 03:20 AM
Borstmayer's Avatar
Borstmayer
I have returned my truck to stock.And as you say no more code's.Thanks for the help.
Do you know if all programers do this.Or is it related to only Bully Dog.I well be calling Bully Dog as i have been driving this truck for 1 year like this.
Again thank you for the help.
Old Feb 7, 2010 | 09:04 AM
tex25025's Avatar
tex25025
The only code that my triple dog threw on a consistent basis when I had it on there was a "U" code which I'm sure was a communication of some type code. I haven't known SCT tuners(although I would do the X3 if you go this route, not the LiveWire. Maybe the TSX as wel, but don't do the LiveWire) or the Spartan Phalanx to throw codes along these lines.
