Bronco II Ford Bronco II
Braided Ribbon.... Ground wire ??
Old Jul 18, 2006 | 08:40 PM
spiritwild's Avatar
spiritwild
87 BII 2.9L
There is a braided steel wire that is about 1/8 thick and 3/4 inches wide hanging from my right side exaust, right under the fire wall.
The other end just has a clip on it like it would just slide onto the frame somewhere, is this just a ground wire ? If so, where was it originally connected ?
Old Jul 18, 2006 | 10:03 PM
Bdox's Avatar
Bdox
Sounds like the ground between the engine and the firewall or the engine to chassis ground. Someone must have removed it and forgot to reinstall.
Old Jul 19, 2006 | 02:29 PM
rebocardo's Avatar
rebocardo
It is a ground wire and it clips onto the body (you will see a ridge there) and grounds the exhaust for a few reasons including the O2 sensor.
I run grounds directly to the battery to a marine terminal. One for the engine (or alt. bolt), body, frame, exhaust, and casing of the voltage regulator. I posted elsewhere about the gauges used.
Old Jul 19, 2006 | 07:54 PM
Bdox's Avatar
Bdox
Good plan Rebo
jerkypants
May 28, 2014 07:20 PM
1930 Dodge
Dec 12, 2012 04:58 AM
97ranger xlt
1983 - 2012 Ranger & B-Series
20
Feb 11, 2012 06:15 AM
1972-34ton
Apr 24, 2009 08:35 PM
getnbz
May 12, 2005 04:34 PM
