2002 Explorer radio
Old Jul 17, 2006 | 06:58 PM
SOONER4EVER's Avatar
SOONER4EVER
2002 Explorer radio
I just bought a 2002 Ford Explorer XLS. It just has the regular AM/FM cassette player. I noticed the radio stays on after I turn the vehicle off and even stays on after the key is taken out. Surely it isn't supposed to do this. Anyone know what might be wrong?
Old Jul 17, 2006 | 07:12 PM
denny 280's Avatar
denny 280
I bet it goes off when you open the door. It can stay on for up to ten minutes unless the door is opened
Old Jul 17, 2006 | 07:22 PM
SOONER4EVER
I just ran out and tried it. The radio stays on when the door is opened. I have to push the power button to turn it off. Also I noticed the dome light dioesn't come on when I open the door.
Old Jul 17, 2006 | 09:22 PM
SOONER4EVER
I noticed that it takes the radio almost exactly 10 minutes to go off. I also noticed that the dome light comes on when I remove the key. It also takes 10 minutes to go off. The steering wheel does not lock when I remove the key. Any ideas what the problem could be?
Old Jul 18, 2006 | 02:10 PM
SOONER4EVER
Could it be the ignition switch? Anyone?
Old Aug 7, 2006 | 04:47 PM
SteveM's Avatar
SteveM
Driver door switch
You said no dome light when you open driver door.
The switch is in door latch, give a good spray with WD40.
I go thru this every rain just life i guess.
Try opening pass door to see if light come on and radio goes out.
Driver door gives me most trouble.
Luck ste
Old Aug 7, 2006 | 10:56 PM
SOONER4EVER
Hi. I get no dome light when opening any of the doors and the radio stays on for 10 minutes no matter which door I open. Also the steering wheel doesn't lock.
lurch16
Feb 27, 2015 02:21 PM
Getsonk
Apr 26, 2013 02:52 PM
rjw1134
Mar 17, 2013 10:41 PM
bartsdad
Oct 17, 2011 06:37 AM
rwatson119
Oct 25, 2002 04:25 PM
