Fuel return line to filter
Old Jul 26, 2006 | 06:37 AM
desiel62's Avatar
desiel62
Thanks "tjc"for the info, when I do the fuel preasure check I' hoping it will reveal something more deffinative.
Old Jul 26, 2006 | 01:20 PM
hareone54's Avatar
hareone54
i previously had the injector pump replaced about 20000 miles ago. hope that isn't what is goin out.
Old Jul 27, 2006 | 06:49 AM
flyboyd8's Avatar
flyboyd8
Desiel62,
The reason I had my IP rebuilt was exactly as yours is doing. The advance govenor is wearing out and it was causing the exact same symtems as yours.
I would look for and talk to a desiel repair shop in your area. The shop I used gave me a turnaround time of less than 48 hrs. they also tested my injectors while i watched and then did a new on to show me the difference.
The lift pump on our motors is only supposed to supply 7 lbs. of fuel presure to the IP, acording to the Standadyne Shop in my area. My truck had 176K when I bought it knowing I needed to have the IP done. it was all still at that time in grey paint. New Injectors are about $32 apiece, and the rebuild of my pump was around $300.
I drive a 93 non/turbo also, My fuel consumption went from 15mpg to Now 21+ MPG and great power.
Please fill in your Signature, about your truck,
Flyboyd8
Old Jul 27, 2006 | 02:23 PM
desiel62's Avatar
desiel62
Thanks for the info Flyboyd8, for the info. I have a feeling it might be the same problem here. I'm going to run some tests first, and try to isolate the problem.I hope. Dave
Old Aug 7, 2006 | 12:09 PM
rickkk's Avatar
rickkk
Return Lines
Hi All,after reading most of the problems due to air in fuel lines,I am looking for a source for the return lines,the short ones connecting one to the next,is their a kit of some sort for all of the return lines? The link from others posts using " lines" takes me to a Brake supply site! ?? Thanks for your help.... Rickk
Old Aug 7, 2006 | 02:51 PM
tjc transport's Avatar
tjc transport
i ain't rite
any international truck dealer will have the fuel return line kit in stock. just ask for a kit for a 7.3 liter
Old Aug 9, 2006 | 11:57 PM
93_E_350's Avatar
93_E_350
I’d go with repairing the return system.
It's hard to find but…
“Fuel system return line restriction: Restriction in fuel return will raise the pressure in the injection pump causing an adverse effect. This can result in loss of power and high smoke levels”
This was taken from a Ford service disk for trucks covering 93 through November 94. I obtained this disk on e-bay, bought it for about 9 bucks out right. You might need special software to view it, ask before you buy. I’m not plugging anyone but it’s the best 9 bucks I ever spent!
93
Old Aug 27, 2006 | 04:27 PM
desiel62's Avatar
desiel62
Talking thanks for the info
I haven't had the time to look at it since my last post. I hope it is just a fuel line return line restriction, some where. Thanks again 93_e_350. Dave L.
3000gtman
29
May 18, 2020 10:32 AM
Cjpower9185
Dec 22, 2015 10:47 PM
lee00
Oct 8, 2015 08:45 AM
jhobbs26
May 1, 2014 01:11 AM
bigern6697
17
Aug 14, 2011 05:29 PM
