TFI Module going bad?
Old Jul 16, 2006 | 04:04 PM
SteelySlayer's Avatar
SteelySlayer
Ive been having problems with my truck ever since I opened up the exhaust a little bit. It ran good for a while, but then just started to run like crap. I dont know much about this stuff, but I have heard that the TFI Modules are known for just randomly going bad. Could this be my problem? I have an '89 F250 with a 300 I6 4x4 and ever since I opened up the exhaust and intake a little I get almost no power, it sounds horrible (almost like its only running on a few cylinders or Im running out of gas) and the little battery charge gauge in my truck says its really low. I also thought that maybe the alternator could be the problem, but I still need to get that tested. Have any of you guys ever had the TFI Module go bad? How did you know it went bad if it did? I had a friend that had one go bad in his mustang, and he bought a new one and it runs good now. Do I even have one in my truck? I posted in the engine forum, but everybody seemed a little reluctant to post. Is this a very common problem with an older pickup like mine? Any advice would help me out, thanks.
Old Jul 16, 2006 | 05:08 PM
clstrfbc's Avatar
clstrfbc
The TFI module switches the voltage on and off to the coil, before the distributor. Normally when it fails, you get no spark, (as opposed to a couple missing cylinders). Sometimes it will work again when it cools down. I have only heard of it stalling out.
You might try the ignition forum.
Old Jul 16, 2006 | 09:23 PM
mississauga's Avatar
mississauga
Both times my ignition modules went bad there was no warning. It just stop running instantly. You indicated that your battery was a little low or not charging. Look after that first and see how the vehicle runs.
Old Jul 17, 2006 | 12:29 PM
spike552's Avatar
spike552
You know i have had the exact same problem with my 87 f-150 i did a google search and came up with this, its little old but still helps to better find the problem http://www.autosafety.org/article.php?did=1216&scid=185I have also found that when you turn the truck off i dont hear it cooling itself and sometimes i do hear it, i havent been able to test it i was wondering if its better to take it to ford and just buy the 40$ tester cuz i can get the code reader for free.
Old Jul 17, 2006 | 01:18 PM
lv2race's Avatar
lv2race
Run your codes.
Old Jul 17, 2006 | 01:54 PM
mississauga
Thanks for the info spike 552.
Old Jul 21, 2006 | 04:16 PM
clstrfbc's Avatar
clstrfbc
How did you open up the intake?
Is this MAP or MAF?
tempest411
Aug 26, 2013 12:33 AM
mxhowes1
Nov 11, 2011 08:39 PM
mxhowes1
Mar 3, 2008 10:05 PM
uscrpick
1978 - 1996 Big Bronco
Sep 12, 2007 08:33 PM
irishguyincc
1983 - 2012 Ranger & B-Series
Aug 25, 2005 08:51 PM
