Can anyone tell me where I can look up TSBs? I wanted to find out what the TSB #s were for the front end death wobble on my 2006 V10 with front coils. I searched the threads on the death wobble but couldn't find out which #s they were. Thanks.
Steering Wheel Oscillations, I found 1 TSB but it is rumored that there is 2 TSB's for this issue. I want to make sure that the stealership doesn't give me the run around.
tsb 06-15-01--05-07 f-super duty steering wheel oscillation: some may exhibit steering wheel oscillation (back-forth) immediately following frt or rear wheel impacts-(pavement joints frost heaves rough roads)-steering wheel motion is typical in the range of plus or minus 5 degress, and typically dampens out in fewer than 5 oscillations. this condition occurs mostly on 4x4 vehicles, and is more evident on trucks equipped with a gas engine(just like yers).thats about it,they should be able to minimize but may not be able to get rid of all!!
Yeah blue that's the tsb your lookin for. My 07 is going in this week for the same problem. Of course after installing dual steering stabilizers which provided little to no help. I'll let you know how I make out.
