Modular V10 (6.8l)
Yikes
Old Jul 16, 2006 | 09:26 AM
Big Rig's Avatar
Big Rig
Yikes
Official: MERCON V is now the ATF
<HR style="COLOR: #666666" SIZE=1><!-- / icon and title --><!-- message -->As anticipated.
Per TSB 06-14-04, MERCON V is now the official ATF and replaces MERCON in all applications for which MERCON was the previously specified fluid.
A copy of the TSB is available at http://cerberus.cowgod.org/tsb06-14-04.pdf.
I copied this from the Tranny forum..
My 02 Ex strictly says only use Mercon for Tranny and Power Steering.
Will Mercon V do dmg??
Big Rig
Old Jul 16, 2006 | 09:48 AM
Antelope V-10's Avatar
Antelope V-10
Not good in my opinion. How can we go from Mercon only to Mercon V? Just because it won't be mfg anymore? Did they change the V to be more non-v compatible? I like the part in the TSB where is says you can NOW service the 4R100 with V. Why NOW and not before?
Thanks for the TSB Bigrig.
Old Jul 16, 2006 | 09:00 PM
Monsta's Avatar
Monsta
Sit. Stay.
Guess there's gonna be a ton of "what tranny fluid to use" threads...again. Just now the answer is different. Maybe this time they won't get so heated.
Folks might just wanna bookmark or save that URL/pdf.
Old Jul 16, 2006 | 09:32 PM
chris60's Avatar
chris60
well, thanks.. I printed a copy of that tsb, and tomorrow I will talk to my parts guy at the dealers.. jeez, I just changed my fluid to!
Old Jul 16, 2006 | 10:13 PM
biz4two's Avatar
biz4two
Arrow
I read it here first at FTE in the SuperDuty forum. Mercon V does have a new version (chemical make-up)...which allows it to work with the 4R100.
biz
_____________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old Jul 16, 2006 | 10:25 PM
ford390gashog's Avatar
ford390gashog
the current mercon v fluids contain less friction modifiers and instead use more stable base oils to prevent the TC shudder.
Old Jul 17, 2006 | 12:18 AM
Antelope V-10
390--- Are those just Ford fluid's that have been upgraded only or are the Wally World, Napa fluids upgraded too?
Old Jul 17, 2006 | 12:24 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I would imagine if they changed the Mercon-V spec, all Mercon V spec'd fluids out there in the aftermarket will change too.
What would I do? Use a brand-name Mercon fluid, like Castrol.
I've said it before, but I'll say it again. I am steadfast against using any Motorcraft fluids in my vehicles. My '96 t-bird had the oil changed at the dealer once with Motorcraft stuff. After 1500 miles, I learned to never do that again. It was BLACK. And this was at only 3K miles total on the engine, so there was no chance it was washing off crud from inside, it was really the oil deteriorating. Castrol was run through that engine for the next 60K miles, never turned more than a slight amber.
Now, their oils are better, but I still shudder at the thought
Old Jul 17, 2006 | 01:46 PM
SLE's Avatar
SLE
Kewart, your oil was black because the dealer put in what ever they had in there barrel, and coming from mecanics that work at the local dealer here it's usually 5w30 or 10w30 of the cheapest crap they can find. The only way you get MC 5w20 is if you specify thats what you want and even then it's suspect depending on whos working and how well they read the work order!
Generally speaking from the guys that have done blackstone oil analysis the MC oil is a very good oil for the price. I'm not saying castrol is a bad oil but your not gaining much of anything other than a lighter wallet and your own peice of mind buy using castrol.
Old Jul 17, 2006 | 02:33 PM
biz4two's Avatar
biz4two
Arrow
I kinda for the most part agree with SLE here.
Took our '05 Odyssey to the dealer for the oil change service (just did not have the time to do it myself). Came back after and found they did not use "HONDA" oil. They used Quaker State...
Not bashing QS, but thought they would give me Honda products when at Honda dealership. That is the only reason I took it to them.
If you do not specify, then they will use the cheapest they have.
biz
_______________________________
Old Jul 17, 2006 | 02:45 PM
krewat's Avatar
krewat
I'm brand loyal to a fault. Work order said Motorcraft, but who knows.
Either way, I've often found other stuff lasts longer. Even their gear lube, regular 80w90, put in a brand-new 8.8" 3.73 rear that I setup (and know it was setup RIGHT) and the oil was pretty ugly pretty quick. Even after break-in, I changed it again, and within 20K miles it was ugly. Used Castrol or one of the other brand names you'd find on the local auto parts store's shelf, it's still quite clean.
I'll be the lone one out here in V10 land that doesn't like Motorcraft fluids, so never mind
buckarooboy
Jan 11, 2015 11:24 AM
ccerniglia
Oil & Lubrication
18
Oct 17, 2008 10:51 PM
Beachbumcook
Aug 29, 2006 10:39 AM
