model for breakerless converson
Old Jul 15, 2006 | 05:53 PM
hotrodfordpickup's Avatar
hotrodfordpickup
Im thinking of changing my single points distrubeter to a solid state setup.. the motor runs really good but iwould like more control over the advance curve and more fire..maybe even to revlimet the motor..it cant be any larger than the stock dist.because the front holly is very close..i live on s.s so cant get crazy with the money..any input would helpfull thanks ...bill..
Old Jul 15, 2006 | 10:14 PM
Putt's Avatar
Putt
Two schools of thought here, Bill.
1. Install a breakerless conversion in the stock Ford points distributor(the Crane XRI has a rev limiter). Other brands are the Pertronix Ignitor, Mallory Unilite, and Accell, I don't think any of those have the rev limiter.
2. Source the wiring for a Duraspark Ignition conversion. ie. the wire harness from distributor to module and module to coil, then purchase the ignition module and distributor from a parts store. No rev limiter there either.
None of these change the advance curve mechanisms, so you would need to recurve whatever distributor you used. There are kits with a selection of springs and adjustable vacuum advance cans, so it is available.
Hope I have helped some.
Old Jul 17, 2006 | 11:13 AM
Mike G's Avatar
Mike G
One more thought to add to Putt's comments. I went with a modified system that runs the 70's Duraspark II distributor (from the salvage yard or favorite parts store) but nixed the associated brain box and wired in a GM HEI ignition module for around $20 in parts and wires. There are instructions here on the site someplace, just need to search...
--Mike
Old Jul 17, 2006 | 12:15 PM
hotrodfordpickup
thanks..for the help..is the duraspark.the unit that ford ran in the 70s if so its cap diamater is to big..the front holly on a 427 is very close..the plug wire touches the carb. if the diameter is the same i would love to try that setup...thanks for you help guys...bill
Old Jul 17, 2006 | 12:26 PM
Kruse's Avatar
Kruse
The early ford electronic distributors have the same diameter as the point systems.
Old Jul 17, 2006 | 02:43 PM
hotrodfordpickup
mike g is there some advantage in running the hei brain..i get a little quesy thinking of putting GM parts on my ford...lol...thanks all of you for the help..bill
Old Jul 17, 2006 | 04:43 PM
Hypoid's Avatar
Hypoid
I havn't bothered changing out the breaker points dizzy yet: I've read complaints about the reliability of Duraspark modules, complaints about the cost of quality modules ($60 to $70 range). I've seen the page Mike G mentioned (lost the bookmark), if I understand right the GM module runs a full 12 volts to the coil, Duraspark does not. Hopefully someone else can tell me if that is fact-or-crap.
What has not been addressed is the second half of your dilemma, handling the secondary voltages. The reason for the big caps is that the smaller caps cross-fire with the higher output voltages. That kind of shoots you down with the room you have (BTW, nice set-up). I've read of some kind of off-set distributer or bushing to clear blowers and such-but there goes the budget.
I'm watching this thread, there's a lot to be learned here.
Good luck, Mike
Old Jul 17, 2006 | 05:04 PM
baddad457's Avatar
baddad457
Funny you say that about the clearance on the 2x4. I have the small block 3x2 intake and it works with the big duraspark cap, but I did have to notch a small piece of casting off the carb body to do it. Been a long time since I had the LR 427 dual 4's but seems there ought to be plenty of room for the dist cap. You don't have the carbs facing forward do you?
Old Jul 17, 2006 | 06:22 PM
hotrodfordpickup
no they are backwards on the stock lowrizer intake
Old Jul 18, 2006 | 09:51 AM
Mike G's Avatar
Mike G
I actually like the simplistics of the HEI unit. When going with the DSII system, you need to get the right box with the blue wire grommet, or you may end up with a unit that has emission curves built in... This was pretty much a wire in deal, mounted it on the firewall atop a heat sink, it just sort of hides there. The unit was I think $20 and I found the distributor in the salvage yard (looking pretty new on a trashed body truck). As far as the distributor width, the necks were all the same size, it the cap base and body that vary. The big caps were not used on the FE equiped motors, however, you can purchase a spacer for the wide head cap if you desire....
--Mike
Old Jul 18, 2006 | 11:49 AM
hotrodfordpickup
Thanks mike for your help.I run heavy no eltronics but with the hei box could i hook up say a msd unit for rev control or to keep me from breaking out???or maybe curv control..bty..thanks for the help..dont know how im going to go i just know i need to have better fire and more control over the advance....thanks bill...
Old Jul 18, 2006 | 02:08 PM
hotrodfordpickup
I can not say enough how great this site is. it is so cool to chat with people who know somthing about FEs..I posted picts at the gallery its a farm truck to drag..hope you like..and thanks again guys for all the help...bill
Old Jul 18, 2006 | 06:39 PM
baddad457's Avatar
baddad457
The big *** HEI distributor sure ain't gonna fit where a large Ford cap doesn't.
Old Jul 20, 2006 | 11:14 AM
Mike G's Avatar
Mike G
Not too sure about the box for spark control and rev limiting, The HEI unit is teh replacement for that or the DSII box. I'm not too savy on the electronics side of the motor, I just know how to get spark to the plugs... The unit is actually only the small (3-inches) 4-prong brain from the mid-90's vehicles, wired in from teh ignition swith to the coil/DSII distributor. I think you can see in my gallery under the progress heading that it looks all stock at the motor (of my old farm truck too).
--Mike
Old Aug 13, 2006 | 10:53 PM
Melchiah's Avatar
Melchiah
ya i am planning on doing it also just cause its smaller and easier to sore as a spare but you have to build a heat sink but the hei module with a ds2 distributor i hooked one up on my buddy's bronco and he loves it here is a diagramn i made hope it helps [IMG][/IMG] And BTW there prolly is Gm parts on your ford anyway since they bought parts from each other rather than maufactung their own fuel pumps was a big one with for though all fords used to come with AC Delco (GM) fuel pumps
