Offroad & 4x4
stuck in 4x4 low help!
Old Jul 15, 2006 | 05:48 PM
vanrebl's Avatar
vanrebl
I have a 2001 F350 7.3 ltr supercab longbed automatic.....
I went fishing yesterday pulled my boat up out of a pretty knarly area so i put it in 4x4 high i think.....when i got to top of hill ...i tried to go back into 2x4 but it wont go back in....it is stuck in 4x4 low.....it was a dry day and i read in a forum that somtimes if the hubs get wet and dirty that can happen....why it would i dont know..its a 4x4 right?
this truck has lock and auto on the hubs and a switch inside the cab
help please!
wayne
Old Jul 15, 2006 | 10:22 PM
fordraceboy's Avatar
fordraceboy
put the hubs in auto and then try backing up... that helps things disengage sometimes..
Old Jul 16, 2006 | 12:06 PM
captain p4's Avatar
captain p4
Make sure it is in neutral, not moving and your foot on the brake when you try to shift back to 2wd or it won't go.
This truck has the ESOF system, right?
Old Jul 16, 2006 | 11:03 PM
vanrebl's Avatar
vanrebl
Thumbs up
yep the putting it in neutral and pushing the brake was the trick....thanks guys for the fast responces
wayne
Old Jul 28, 2006 | 03:29 AM
khadma's Avatar
khadma
Carpenter Local 745
In another forum, another person has a problem with their Excursion hub being stuck/locked in the auto position. He was told to take it apart and check the needle bearings and overhaul the hub, could this be the problem? Or was he disengaging the 4x system incorrectly?
He has the ESOF system too, I mentioned backing up, but I was told this would not work. I seems no one has an answer for him. I thought you guys would know. I consider this forum to be the 4x4 experts.
Old Jul 28, 2006 | 02:11 PM
captain p4's Avatar
captain p4
Well, backing up is useless on this type of system. The poster of this thread was just disengaging incorrectly. If the actual hub that you turn on the wheel is stuck, then I'm not sure what the problem is, but rebuilding sounds like the right idea. If his truck is stuck in 4wheel low, just do what I said earlier. Other than that I'm not sure.
It should shift on the fly out of 4wheel hi.
f350v10415
Aug 29, 2013 07:47 AM
DuallyMike
Aug 25, 2011 08:27 AM
ct7491
Feb 2, 2008 02:18 AM
LasVegas F250
Mar 4, 2007 04:50 PM
Bronco2Nic
Sep 28, 2005 10:45 AM
