Well I just got home from dropping of my 2005 4x4 F-450 at the dealer . The transmission was acting up again (snapring failure) this is the secound time it has failed, the first time was at 14000 miles now I have 16000 miles on it . I'm so pissed off It's gonna take two weeks to fix and who knows how long it's gonna last this time.I pull a 18000# gooseneck trailer around on occasion but thats what this truck is made for. I don't know if I'm gonna keep this thing or not. I went through 5 e4od trannys in my 92 f-350 it was the planetary gear in all of those that went bad . Im thinking about a kodiak 4x4 with the allison auto .Does any body have any suggestions
And you said just the trailer is 18000# right? That would be over. Then add whatever you are putting on that trailer. Sounds like it is the jockey not the horse to me.
This is BS. My '04 550 has gone through 2 snap rings\cases as well. 2 different operators over 2 years.
The weight may have something to do with it, because mine is right at the max, but they still ought to hold up. I bought a 550 because I knew I would overload a 450.
TransGo has a shift kit and a snap ring that is supposedly 400% stronger. I have both in my 550's and so far so good. Ford warranted the case, TC, and overhaul kit, I paid the labor and parts for the rest. I'm not an expert, but my repair shop said that one of the pressures on the snap ring is over 400 PSI which they said is waaaaaay too much. The shift kit drops it down 25%.
