finally back to racing
last night was the first time I got to race in a month and was starting to have withdrawls. but got the trans done last weekend and took it out last night, I finallly have all 3 gears again. Modified class I goofed up and got out of the track so I lost, and in Open class I redlighted on one race so ended up with third place there. The truck was running pretty good but I have got to find out how to get more traction, in first gear as soon as I take off I can't hit second fast enough as it just boils the tires, so I guess I now know what happens when you dump 800ft/lbs of torque solidly through 39.5 boggers, they don't hold.
I am not getting enough weight on the back I guess or maybe to low geared, but I don't think I have enough power to get away with high range, so maybe a second gear start guess I will have to try that next weekend. I don't want to regear this thing this year, maybe over the winter. also think I might look into moving the front axle forward a little and that might help.
The vids didn't come out very well but if I get a chance I will try to upload one or 2.
Rob,
Brother I hate to do this to you again, but I gotta say it. Your having traction problems????? I got two words for ya...Goodyear Superscoop. Along with the Lenco, those are something I have always wanted too. I can't justify them, cause two weeks ago in Llano, my cut boggers (which you showed me how to cut) Hooked up way beyond my expectations. But you could definatly put some SC's to the test. Anyway, I hope that thought doesn't haunt you like it does me. But that's my solution for you. But at that point I think a mud wheelie bar would be in order.
Originally Posted by Thomsen
Good to see ya got it up and running again. Now you need to come to sturgis and show us how it's done.
Originally Posted by RubberDuck
Rob,
If I can find a set of 37x13 or 38.5x11 boggers that aren't out of range I might put them on the front and drop the rear gears from teh current 4.63 to the set of 4.30 I have sitting here and that will help some too. Besides if I do that paddle tires then could be shorter and run my 35s on the front against the paddles on the back and be ok.
Hit up some of the ag dealers in your area and see if they have anything, i've seen a couple rail's run 10.00x20's ag tires or the tires used on the irrigation pivot's, then the lighten em' up as much as they can and run em' front and rear. The 2 rails that i've seen run that type of setup cleaned house, maybe that's something you should look into, but that would require different rims or adapters of some sort.
Have you looked into some lead weights of some sorts over the rear tires perhaps, cause i have yet to see rules about adding weights and their placement.
Originally Posted by proeliator
Awesome to hear that you're back in the saddle, thats always a great feeling after some frustrating downtime. If you don't have enough weight in the tail put the keg back there instead of in the cab with you. Should do the trick
Don't tempt Rob....then the next time I see him at Reasnor I might be stuck riding in the back instead of the cab. So he can finally show me how it "really feels."
Also....stop giving him ideas about running different tires for open! Who do you think is going to get stuck helping him put them on when I show up to *watch* the races. Haha
Glad to see its back together. I think I'll be able to make it to the races this month, Rob, but my sister might be getting back from Arizona either that day or the next day, need to ask about that. Either way!
LMPLLC
07-18-2012 05:54 PM
