Instrument Panel, no lights
Old Jul 15, 2006 | 10:24 AM
finfanmo's Avatar
finfanmo
About 2 weeks ago, I lost the lights in my instrument cluster and my tail lights. It's on a 98 Explorer. When I turn on the headlights, the radio display doesn't dim either. All fuses and bulbs are good.
Old Jul 15, 2006 | 12:29 PM
westtntrucker's Avatar
westtntrucker
sounds to me like there is a problem with the fuse for the brake lights. May not be blown but corroded? I would try and pull the fuse for the brake lights and try a new fuse in there and possibly get some contact cleaner( pull positive cable and turn on headlight switch before doing this) and clean all the contacts on the fuse panel.
Old Jul 15, 2006 | 05:57 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome finfanmo, to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jul 16, 2006 | 09:24 AM
finfanmo's Avatar
finfanmo
I forgot to add that the odd thing is that I have brake lights and headlights, but when I turn the headlights on, neither the radio display nor the temp/heading display dims. I've got to take it out of town this afternoon, and it sure would be great to have tail lights tonight. I'll definitely check the fuses again, and any other input would be greatly appreciated.
By the way, I'd heard somewhere that a bad pigtail would cause this. What do you think?
Old Jul 16, 2006 | 01:14 PM
Franklin2's Avatar
Franklin2
Here's a digram for your explorer.
http://www.autozone.com/images/cds/g...3d800ba9ee.gif
Look in the very middle of the diagram where it says "Hot at all times fuse #3, 15 amp". This is were your running lights circuit starts.
What I would do is pull the headlight switch, and take some voltage readings. You should have voltage on the tan/white wire. When you pull on the switch you should have voltage on the white/black wire.
I would suspect you have a problem with the tan/white wire or the switch itself. Inside the switch is were the instrument cluster fuse gets it's power from the tan/white. So that explains why the running lights and the instrument lights are out.
The pigtail you may have heard of would be the plug going into the headlight switch. While you have the switch out, see if you have any melted wiring at the switch.
Gasrgoose
2009 - 2014 F150
Jan 7, 2014 07:48 PM
Mormakil
Aerostar
Jul 2, 2006 07:03 AM
I_Thnk_Ford
Jan 5, 2005 07:46 AM
Scrapiron66
May 17, 2004 02:27 PM
