1995 Checking E4OD MLPS.........
Old Jul 14, 2006 | 06:34 PM
ptt's Avatar
ptt
Is there any special way nto check this on my van? I have an intermittant hard shift (sometimes during cold tranny fluid drive so I think it may not be a heat issue). I want to see if there is corrosion in the connector. Thanks.
Old Jul 15, 2006 | 09:04 AM
Clubwagon's Avatar
Clubwagon
You can do a sweep test with a multimeter but that's about it. The problem isn't usually the connector, its the rheostat inside. They will develope a bad spot on the contacts and give an intermittant faulty reading. Very difficult to diagnose if it hasn't set a code.
In most cases, if you think there may be a problem, replace it and see if the problem goes away. If not, that wasn't it.
Steve
'95 Clubwagon XLT
Old Jul 16, 2006 | 11:10 AM
ptt's Avatar
ptt
Mlps
As this vehicle is at that magic age where original factory parts start failing (around 10 years) I'll replace it like you say. Is there a step by step available? !Thanks Steve
Old Jul 16, 2006 | 01:00 PM
Clubwagon's Avatar
Clubwagon
I don't know if there is a proceedure anywhere. Its pretty straight foreward. You will note the mounting holes are slotted. When you remove the old one note its position then try to match it with the new one. Once its in, adjust it so the vehicle will start in neutral and park. That should do it.
Steve
'95 Clubwagon XLT
Old Jul 16, 2006 | 01:24 PM
ptt's Avatar
ptt
Mlps
I'll be replacing it as soon as we get a break in this heatwave. Heat index is at 105F today! I'll do a followup post for sure. Thanks again.
lalberts
22
Jan 11, 2017 10:16 PM
kbf1961
Oct 17, 2015 10:05 PM
Whitey Ford
21
Aug 18, 2015 04:42 PM
phillyfreak
Aug 12, 2011 11:19 PM
Jaaaaaaackman
Sep 21, 2007 09:33 PM
