72 460
Old Aug 17, 1999 | 06:06 PM
Darryl's Avatar
Darryl
I'm installing a 72 460 in my 78 f100.I want to put a serpentine belt on it.Would brackets from a newer model bolt to older block? Does anyone know of an aftermarket kit?
Old Aug 17, 1999 | 08:49 PM
jowilker's Avatar
jowilker
Darryl you are probbly going to have to engineer this one yourself. Have you seen a late model 460 with a serpentine belt on it? Do you have any idea how to figure the length of the belt, if you could get all of the pullies.
Lots of luck to ya buddy,
John
Old Aug 19, 1999 | 04:46 PM
390fe's Avatar
390fe
72 460
You might have to change balancers. Most early balancers used three bolt pulleys and late models used four bolt pulleys. Also, late model serpentine use reverse rotation waterpumps and fans, I think. I could be wrong here....
Old Aug 25, 1999 | 09:01 PM
Caleb
Guest
Posts: n/a
72 460
one VERY important thing to make sure of is that everything still spins the right direction with a serpentine belt, did the 460's with a serpentine belt have a waterpump that spun a different direction? I dont know, but it could lead to some big problems if they did and you dont check
Old Aug 25, 1999 | 09:51 PM
1scott's Avatar
1scott
greentruck72
32
Apr 2, 2017 12:39 AM
greentruck72
Nov 17, 2016 08:27 AM
jdgreen72
May 15, 2007 10:40 AM
Scrapiron66
Engine Swaps
Feb 16, 2004 03:01 PM
marvmart
Exhaust Systems
Dec 3, 2003 06:18 PM
