1978 - 1996 Big Bronco
Fuel injectors?
Old Jul 13, 2006 | 07:23 PM
92GASHOG's Avatar
92GASHOG
Fuel injectors?
My '92 Bronco 5.8 L stutters on take off and will not exceed 45 MPH. I have been chasing this problem for weeks and am in need of advice. My local Ford dealer recommended $3000 in repairs for just about everything that wasnt OEM I ended up replacing the PCM and in still feels like it a cylinder missing. Could this be the fuel pump or injectors or does anyone have any other suggestions?
Old Jul 14, 2006 | 12:01 AM
greystreak92's Avatar
greystreak92
Welcome to FTE and the Big BRonco Forum. We will endeavor to get you the most accurate info. we can muster.
Ok, you have a 92. Have you pulled the EEC-IV computer codes? Did the dealer pull them? If so, what codes were being thrown? If not, don't do another thing until you get the codes. Replacing the PCM is an expensive investment especially if it was done without pulling the codes first. The old unit may have nothing wrong with it. Once you have the codes troubleshooting will be much much simpler. A Haynes manual or www.fordfuelinjection.com will shed a lot more light on the procedure for pulling codes.
Old Jul 14, 2006 | 12:29 AM
dallas lewis's Avatar
dallas lewis
It would probably be a good idea to check everything included in a standard tune up as well. I hate to suggest something that sounds so obvious, but you would be surprised how many people miss little things like that. I developed a shutter in my 93 and tried everything under the sun to fix it, and it turned out that I had a few spark plug wires that were nearly burned in half. Let us know what you've tried to fix the problem so far so that we don't recommend things that you've already tried.Good luck
Old Jul 14, 2006 | 11:26 AM
Kemicalburns's Avatar
Kemicalburns
do what grey said. also check fuel pressure at the rail. but this sounds to me like a clogged Cat converter. If you can upbolt the Y pipe from the exhaust manifolds and drive it you should figure out quickly if that is your problem.
Old Jul 19, 2006 | 06:57 PM
92GASHOG's Avatar
92GASHOG
Thanks guys, the dealer was giving me a headache. I' ll check back once this is corrected and let ya know what was wrong.
Old Aug 1, 2006 | 09:39 AM
92GASHOG's Avatar
92GASHOG
You guys were right, The p.c.m. was probably working fine, I pulled it out of the dealer and discovered the distributer was fried.....spent a few afternoons in my driveway and replaced the dist, wires and sparkplugs and its running like a scalded dog again.......thanks for the advice and I'll check in here first in the future.
Old Aug 1, 2006 | 10:13 PM
greystreak92
Just glad to hear the truck is back up and running. Good luck and don't hesitate to ask... my signature is my outlook on it.
Old Aug 2, 2006 | 12:52 AM
yamaweezle's Avatar
yamaweezle
time to find a new dealer to go to for service, eh? they couldn't find a bad dist.? hmmmmz, wierd...
Dan92
Feb 22, 2017 03:14 PM
darknight1028
Sep 21, 2015 11:25 AM
wr310rdr
Jul 26, 2014 11:58 AM
coloradotoy
Dec 4, 2009 07:16 PM
Aerocook
Aerostar
Jan 17, 2007 05:20 AM
