302 oil pressure
302 oil pressure
I have a older year model 302 and when it warms up the oil pressure drops dramatically. Is there a quick fix in a oil additive such as dura lube, slick 50,etc. I know the oil pickup screen is good and the oil is fresh 20w50. After warm up I only show 25 Lbs. pressure going down the highway on my aftermarket mechanical gauge.
302 oil pressure
The main cause of low oil presure in older engines, is that the rod and main bearings are worn and allowing excessives oil leaks inside the engine, there is not fix it in a can, but you can up your oil presure slightly with oil additives like STP. What they do is thicken the oil up. You can also get the same result by using straight 40Wt oil. Additives like dura lube, Slick 50 are PTF (tethlon) coathings, that help prevent engine wear, they do nothing for engines that are already worn,
Dave
Dave
NashvegasMatt
Sep 26, 2016 05:44 PM
Lneidlinger
Sep 29, 2015 05:59 PM
Jamegan
Sep 26, 2015 08:54 PM
Luv2Fish_KC
Oil & Lubrication
Dec 18, 2003 01:42 PM
