7.3 Performance Upgrades ?????
Old Jul 17, 2006 | 11:53 AM
1969fordguy's Avatar
1969fordguy
rockyrider: I let the truck downshift when it needs to and then turn off the overdrive. If I could ever remember I would probably turn off the OD before starting up a hill so that the engine doesn't rev. so high when it downshifts. The highest RPM I can stand to drive my truck is at 3000 RPM. Pulling a 28' boxtrailer with my mustang and tools in it the EGTs got up to 1150 and it was still going up, by using the lower gear and increasing RPM the EGTs dropped to 1000 or so. I believe that 1200 it the max limit for EGT. Having the power to pull at whatever speed is nice, but the gauges force me to slow down and take it easy. Oh well, it does keep one from getting tickets...
Old Jul 17, 2006 | 12:43 PM
lukecline's Avatar
lukecline
i use 1250 as my max sustained temp, but with my new ic and turbo setup i have yet to worry about that.
Old Jul 18, 2006 | 09:33 PM
clay01's Avatar
clay01
I'm kind of new to the diesel side of this board. I just traded in my 86 F-150 351 H.O. for a 95 Powerstroke. One of the earlier posts stated somthing about making a DIY intake. Does anyone have links to directions/pics? Thanks.
John
Old Jul 27, 2006 | 11:19 PM
Level2's Avatar
Level2
You might consider a new lift pump if you change the injectors. I have heard the factory lift pump wont support a great deal over the stock level injectors.
Old Jul 28, 2006 | 11:19 AM
lukecline's Avatar
lukecline
lift pump is built into the stock pump in valley, there is no way to upgrade unless you switch to an aftermarket electric fuel system. Stock fuel pump is adequate to 400 +/- hp.
Old Jul 28, 2006 | 05:46 PM
1997F-350's Avatar
1997F-350
Originally Posted by the weez
Curious about the Stage-1's. How much will they add to the performance, assuming I already have all the other common mods.
How much time for a typical install?
i took about 6 hours by myself going slow. i also had to swap all my solenoids so it took longer. definitely not a job you wanna rush but can be done in one day...
and for your 2nd part of the question. well lets just say my truck is no longer a dog. its has the same effect a corvette or mustang does. you hit the go pedal and you get thrown into the back of your seat. no b.s.!!!!!
John
whats needed:
1.wix 46637 filter. fleetfilter.com under 20 bucks also a site sponsor.
2.heavy duty t-band clamp. 6 bucks or so at napa (hard to see in pic but its there)
3.4" 45* exhaust elbow. ( possible trimming required of pipe you buy) airflo.com 25 bucks or so.
enjoy
fellro86
Missouri Chapter
529
Dec 19, 2018 02:03 PM
Jimjdb1
Michigan Chapter
288
Oct 15, 2016 06:54 AM
smallblock351w
29
Sep 21, 2006 04:54 PM
chixdigit
Jun 16, 2006 12:24 PM
