I put a 400 out of a 76 Lincoln into my 79 F250. I switched out the oil pan, pulleys and everything else.
The crankshaft pulley was larger on the Lincoln (one more row for the air conditioner unit), I switched out all the pulleys but not the balancer. My engine's been dieseling, I'm going to mess with the carb, vacuum and timing tomorrow, but I wanted to see if changing the pulleys would've affected the balancer. Just want to make sure that's not the problem.
